Old 05-10-2003, 06:51 AM   #2206
Herminator's Avatar
Send a message via ICQ to Herminator
This is my car after the first of two finals, this one I still won by a lap after starting last happened when I was lapping some inconsiderate driver and they sent both of our cars into the grass, must of contacted a small stone or maybe the edge of the tarmac.
Herminator is offline   Reply With Quote
Old 05-10-2003, 08:39 AM   #2207
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Can you say that it`s time for a PAL drive unit
Just be glad that ste spur was the only thing that got messed up
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 05-11-2003, 07:08 AM   #2208
Hi there Dave and the Cuda nuts,
I'm thinking of buying a new R2... I'm a bit of a newbie so I appreciate the R2's purported "tank" qualities. In any case, looking at this thread, it looks like there are quite a lot of parts that I could/should buy...
What are considered must haves?
What would be good to have etc.
(I can't seem to find what I need to know in this thread... so sorry, if its already been said)
A list would be nice
Thanks in advance!
jwwu is offline   Reply With Quote
Old 05-11-2003, 08:25 AM   #2209
Herminator's Avatar
Thanks in advance!
well I've been running it as kit spec for the last couple months, other than an extra normal diff for the front, so thats one thing to add to the shopping list.
Spur gear wobble is one thing to think about, I've stripped a few spurs, on from building it first time with a wobbly spur, one from setting the mesh too loose becuase it's not easy to get to the lower motor screw and so you have to take care, one from an off where something must of hit the spur to knock a few teeth off. Two ways of helping the spur situation, alloy shaft holders or Speedway PAL drive system. It seems the drivesystem is the better option, both is best
You'll want to get a few spares, the car is strong but not indestructable, although I'm yet to break anything. You may want alloy c-hubs out of any alloy suspension parts, then rear hubs and then steering knuckles, although they are mostly for looks.
Personaly I don't like the bleed screw type shock caps and so I'm getting bladder type caps from yokomo which fit as a direct replacement.
You may want a few sway bars to try help setting up.
Other bits are nice looking or help a little with weight or quick changes. The kit doesn't really need weight removed, I have had to add 35grams to stay within the 1500gram limit.
Old 05-11-2003, 03:50 PM   #2210
Thanks in advance!
Well..
the Best 3 parts that you can get for the CUda to make it bullet proof ae in the following order..
1) PAL Drive system
2) Alloy front C-Hubs
3) front & rear alloy senter shaft holders
This is it . you wont ned any thing els for this car
-Dave
Old 05-11-2003, 04:01 PM   #2211
Herminator's Avatar
Originally posted by JDM_DOHC_SiR
Well..
1) PAL Drive system
-Dave
what if he doesn't want to run a one way
it would be better for a new driver to use a normal diff, less spinning out while braking worries
Old 05-11-2003, 04:09 PM   #2212
Well I would say more practice
You could go out and buy the center drive shaft if you really wanted to have fun
-Dave
Old 05-11-2003, 04:23 PM   #2213
Exclamation Well took the R1 EXCEL Cuda to the track yester day
I just got finished switching out my broken Kai Chassis for the New EXCEL one on my Purple R1 Cuda and took it for a spin... All I can say is Wow the batterys were moved 1mm closer to the driveshaft than on the Kai one and also they were moved 2mm forward So this made for some interesting Setups that I had to work with.. The car Has the PAL short arm conversion and PAL upped deck so you R2 owners...this will seem a bit different for set ups
anyways here it is
the
Front
Springs-1.5x5.5
Oil-400 or 40
caster-6 deg
toe-0
camber- 1.5-deg
normal shock pistion
Rear
Springs-1.4x5.25
Oil-500 or 50
toe-2-deg (new optional toe block from PAL the norm is 2.8)
camber- 1.0-deg
tires Sorex 32R
insert HPI Green
Body Stratus 2.0
This set up was for a medium Hi grip track that was fairly large
I`ll get some pics up tommorow
-Dave
Old 05-11-2003, 10:13 PM   #2214
rcruv's Avatar
Default Re: Well took the R1 EXCEL Cuda to the track yester day
You're lucky to be able to buy Kai chassis.
Is R2 pretty much different from R1?
anyways here it is
the
Front
Springs-1.5x5.5
Oil-400 or 40
caster-6 deg
toe-0
camber- 1.5-deg
Rear
Springs-1.4x5.25
Oil-500 or 50
camber- 1.0-deg
tires Sorex 32R
insert HPI Green
Body Stratus 2.0
-Dave
rcruv is offline   Reply With Quote
Old 05-12-2003, 06:46 AM   #2215
Default Re: Re: Well took the R1 EXCEL Cuda to the track yester day
Wow Have not see you post here in a While
Welcome back!!
Well the R2 is pretty much a revamp of the R1 .. ..they went and fixed all of the Chassis balance weak points sus arm weak points and front one way problems.. also they added a few new goodies like threaded shock bodies and a slightly thicker shock towers and upper deck
-Dave
Old 05-12-2003, 03:05 PM   #2216
Herminator's Avatar
we finaly managed some outdoor racing at my club, only two rounds timed though since we were freezing our fingers off.
needed to raise the chassis height to around 8mm since the tarmac is kind of bumpy. I was running 15x4chrome motor which was ok but I was obviously disadvantaged compared to the few drivers using 12T's but with the one way I was able to show them up in the corners. With the two leaders crashing everynow and again I was able to keep on the same lap as them although my transponder wasn't working well, it seems the alloy strap is blocking it's signal. Will reduce the rear toe for next week, the car was pushing a little although grip was yet again good with CS22's.
Got my parcel from Steve today alloy battery strap looks very nice with the blue alloy posts, just needed to drill the strap holes to 4mm and now it's perfect. Also had time to fit the yokomo shock caps, liking them a lot too, less leaks and look nicer too
Now need to get the new 3300's built up, my 3000's are showing their age with poor capacity and don't think they'll survive 5mins with a 12T, they were strugling with my 15 I'll never charge NiMH's the day before I race again.
Old 05-12-2003, 03:13 PM   #2217
Cool
I just got the rest of my Stuff from steve this morning too ..Just wait and see what I`ll be posting in the next day or two heheeheh
Also Hermi` what batterys did you get from steve?? any good #`s
-Dave
Old 05-12-2003, 03:28 PM   #2218
Herminator's Avatar
Cool
-Dave
Finaly you'll show us your goodies
cells are Epic, never heard of them myself but Steve says they are good he made a mistake with some integy's so "found" these
one set has 619secs 1.206v at 20amps
second set 613secs 1.207v
they also have 30amp numbers so I'm not sure if they've been done at both rates or one is a calculated.
Old 05-12-2003, 03:34 PM   #2219
Wow even for 20A those are some pretty good #s
I might have to pic some up
-Dave
Old 05-12-2003, 04:13 PM   #2220
Default Fit R2 arms on R1
Hi
Just wondering if its possible to fit R2 arms on R1. I suppouse that you must to move the shock towers with spacers, what else???, Also with this is possible to user R2 sway bars??
TNX
martinm is offline   Reply With Quote
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
