Barracuda from Alex racing >
Like Tree1Likes
Old 04-28-2003, 03:54 PM
  #2086
Third times the charm
DOTMAN is offline
  #2087
DOTMAN is offline
Old 04-28-2003, 03:55 PM
  #2088
Herminator's Avatar
Originally posted by DOTMAN
[IMG]C:\\sonypictures\cars\dsc00523.jpg[/IMG]
you can't link to a picture on your hard drive, you need to attach it (below the reply box) and be carefull about file size.
Herminator is offline
  #2089
DOTMAN is offline
Old 04-28-2003, 03:56 PM
  #2090
My new shell
DOTMAN is offline
Old 04-28-2003, 03:57 PM
  #2091
Reedy Race Special!
DOTMAN is offline
  #2092
DOTMAN is offline
Old 04-28-2003, 04:04 PM
  #2093
Regional Moderator
Post SWEET
Dotman........... looking good
Ko Racer is offline
Old 04-29-2003, 07:11 AM
  #2094
fai
Regional Moderator
fai's Avatar
Friends: Missed this forum for nearly two weeks and now come back!
JDM: JetHobby HK now has R2 parts in stock! Hope they also have the PAL drivetrain!!
You're very close to Japan Ah!
fai is offline
Old 04-29-2003, 07:19 AM
  #2095
fai
Regional Moderator
fai's Avatar
Friends: Just played with a new setting last time at track: reversed A-arms hex-balls, and then placed a 1.0mm spacer underneath! This setting really speeds up cornering a little bit! But then problem came... As the ball is reversed, the 'contacting' area with the lower chasis is greatly reduced, so a small crash of the car will compress the hex ball 'hardly' into the chasis... I found this when I did the cleaning: a 'deep mark' on the chasis under the balls!
(Pic from a Japanese website... Sorry!)
fai is offline
Old 04-29-2003, 08:03 AM
  #2096
Herminator's Avatar
So what does that do to the overall height of the balls and suspension?
Old 04-29-2003, 03:19 PM
  #2097
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Welcome back Fai!!
I hope that you are staying away from all of that SARS Crud
Anyways glad to see that your back..!!
Speaking of being back!!!
I`m back in the Home Pad now in Japan ..Stand buy for some really trick stuff in the next couple of days
-Dave
JDM_DOHC_SiR is offline
Old 04-29-2003, 03:21 PM
  #2098
Reedy Race Special!
Nice Cuda`s
-Dave
Old 04-29-2003, 11:44 PM
  #2099
fai
Regional Moderator
fai's Avatar
I think that should change the roll centre a little bit (actually, not really know the theory behind... )... Please note mine is a R1! For R2, I think using the mid span A-arm should gives us enough steering for tight track!
fai is offline
Old 04-29-2003, 11:47 PM
  #2100
fai
Regional Moderator
fai's Avatar
Originally posted by JDM_DOHC_SiR
Welcome back Fai!!
-Dave
Dave: Thanks! Happy to see that you're back to Japan finally! I think you've to settle down for some while before go shopping RC stuffs!
fai is offline
