Old 04-23-2003, 10:37 AM   #2041
SpeedTech's Avatar
Hi Guys,
we'll have a couple setup sheet posted on www.alexracingusa.com soon these setups are developed by Dave Berger, who has consistently made the A-main with his Cuda at our local track and it is one of best drivers around in my opinion He has spend countless hours at the track developing setups for us, thank you Dave! and congrats on another great run last night.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 04-23-2003, 04:25 PM   #2042
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by SpeedTech
Hi Guys,
Steve Wang
Hey Steve.. I don't see them on the site..???
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-23-2003, 04:51 PM   #2043
Herminator's Avatar
Send a message via ICQ to Herminator
-Dave
he said soon
you getting worried you're going to get your butt kicked when you get home to Japan? need some secret new setups
Herminator is offline   Reply With Quote
Old 04-23-2003, 05:02 PM   #2044
Originally posted by Herminator
he said soon
Nope ...
I just have to set up my cars just a tad bit different untill I get the R2's in a couple of weeks .. .
I have tons of new stuff just waiting to be tried out
-Dave
Old 04-23-2003, 06:42 PM   #2045
JohnA's Avatar
Started to put the R2 together last night and have a question:
When attatching the top deck I found if I sc rewed it down really tight the plastic gear covers flex a bit and cause the deck to lift a bit at the ends. Has anyone else noticed this? How tightly do you screw the deck on?
Also there is a little plastic piece that fits inside the front one-way cups, I couldn't see which bit this was supposed to be, any pointers??
JohnA is offline   Reply With Quote
Old 04-23-2003, 06:49 PM   #2046
Macky's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Macky Send a message via Yahoo to Macky
Just use the black o-rings for the one-way outdrives.
Macky is offline   Reply With Quote
Old 04-23-2003, 07:21 PM   #2047
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Hi Guys,
Steve Wang
Thanx Stevo but...
I wouldn't say I've been finding setups so much as just learning the car & trying to figure out wtf is up with the latest batch of Sorex 36R tyres
The So-Cal layout this week was back to somewhat of a normal flow and I have gone back to more of a standard setup with the longer susp arms which I think are on the car to stay. Midspan are tricky to drive on, some may like that kind of twitch reaction, whereas the longer arms are certainly more stable once the bite comes up on the track.
1.2mm & 1.0mm swaybars front & rear 40wt/30wt oil 5mm ride height, 3mm droop. No roll center, anti-squat, or anti-dive yet.
I agree with Dave that the CUDA almost requires the swaybars to "feel" right.
I'd say to start with... stock setup with the sway-bars would be a good default setup for anyplace, what do you think Dave ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-23-2003, 07:24 PM   #2048
The deck should not be lifting. The chassis may be tweaked a little. The diff hubs may be applying pressure on the chassis. Unscrew the diff hubs to reduce the pressure on the chassis and try again.
Make sure you assemble the chassis on a flat surface such as a setup board. Screw the top deck in while holding the lower deck firmly down on the flat surface. It should sit flat on the setup board.
Like Macky said, use the black black o-rings in the one-way outdrive cups. I'm pretty sure they meant you to use the o-rings, it may have been drawn incorrectly on the diagram.
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 04-23-2003, 07:32 PM   #2049
hmmm. I noticed that too with the kit/plastic center shaft holders, the optional aluminium holders take care of that nicely
Old 04-23-2003, 07:32 PM   #2050
http://www.alexracingusa.com/images/A6720B.gif
Old 04-23-2003, 07:51 PM   #2051
JohnA's Avatar
It's a good job I have a money tree in the garden!!!
Thanks for the help guys, I'm sure I'll get it sorted.
Old 04-24-2003, 11:28 AM   #2052
Thanx Stevo but...
Sorex 36R's?? man it must be hot in Cali' .. I still Like the Yokomo 7B's when it's about 50~75 outside ...
Also the sway bars ...are a much needed Item. ...I like to use one size bigger up front than I do in the rear... 1.4F & 1.2R....but this is with the PAL Short Span arms and Stock racing
-Dave
Old 04-24-2003, 11:37 AM   #2053
A must if you don't plan on buying the PAL drive system
-Dave
Old 04-24-2003, 01:08 PM   #2054
Default Re: Re: Oneway problem
Sounds like one of the one~way bearings is shot... I can get replacement one~way bearing inserts for the Cuda ..
Hit me up in 10 Days and I'll be able to help you out
-Dave
Thank you!!
I will wait.
Nice to be helped by this cuda gurus group!!!
martinm is offline   Reply With Quote
Old 04-25-2003, 06:20 AM   #2055
Default Re: Re: Re: Oneway problem
Originally posted by martinm
Thank you!!
I will wait.
Not a problem.. Glad to be of Help
-Dave
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
