Barracuda from Alex racing
#1951
Originally posted by SpeedTech
Hi Guys,
in case you guys are wondering, we got the PAL system and the aluminum c-hub, rear hub carrier, and a lot of other R2 goodies in stock today. I'm sorting through them and should have them online tonight
Steve Wang
Hi Guys,
Steve Wang
-Dave
P.S. what colors did you get in.??
#1952
Originally posted by Herminator
By far my best nights racing, the car was very predictable and seems able to make very good use of the grip available. I'm almost sad that it was the last night of the indoor championship, one more week and it will be a fun night, some team event I think. The car really is impressive and I had the most fun racing for an awful long time, it was nice being close to as fast as the top two instead of either being a fair bit behind or them having a bad day. Guys normaly challenging me were left for dust
-Dave
#1953
my motor is great, my cells aren't though
I'm using two packs of SMH 3000's non matched and mostly I charge the day before, a terrible techinique for metal hydrides but I often don't have time the day of the racing to charge, I just managed to squeeze in charging between heats today but wouldn't have time before the racing to do two packs. I only use around 1800mah for a race, motor is now geared as good as it will get indoors. My charger I blew up only does 5amps max charge and isn't great for metal hydrides, I was borrowing one the same for today and will be for the next couple weeks. I'm planning on getting two packs of good 3300GP's when I order a charger from Steve so I have some good cells for outdoors. When we move back indoors I'm tempted to get some older matched 2000's, the car that was blowing me away the most in the 2nd run was using 2000's and his motor is nothing special, he says the cells are a huge difference from his 3000's and it showed.
#1954
-Dave
#1955
R1 Cuda For Sale...
#1956
Hi Guys,
The Speed Tech R/C site was updated with the latest Barracuda R2 hop-ups including the PAL drive system.
Steve Wang
Steve Wang
#1957
Hi Guys,
Steve Wang
Hi Guys,
Steve Wang
#1958
Hi Guys,
Steve Wang
Hi Guys,
Steve Wang
thats what I have been waiting to here.....but I have a question.... did you get the upper Tie Rod mounts for the Xenon/EXCEL Hubs..??
-Dave
#1959
Re: R1 Cuda For Sale...
Originally posted by Bartz!
There's a guy selling an R1 on eBay right now. $180
Cuda Auction
Probablly worth checking out.
Cuda Auction
-Dave
#1962
Originally posted by kansasracer
finally got it together and so the questions start
Really the only question that I have is
Is the drivetrain SUPER loud until the breakin process has been completed?
Thanks in advance!!
Mike
Thanks in advance!!
Mike
The Drive Train will be come less noisy over time..
Also did you do any prep work on the gears?
-Dave
#1964
CUDA setups...lets share
Hello DAVE...and all the rest of the CUDA gang.
Wanger, Madjack & I have been coming up with some pretty good stuff on the CUDA lately as we all run a different setup at So-cal. Just curious what you folks have found to be of use, particulary the stuff that's a bit uncharted ? ? ?
Last night at the races (admittedly the So-Cal banking is not the norm) I found that 2mm of roll center did wonders for stability with the shock positioned at the outside holes top & bottom for MAX steering. And it seems that rear anti-squat is not a friendly setup for the CUDA (too much on power steering)
Later this eve hope to have time to post latest set-up sheet.
Quick list...
Motor/Gear=Reedy Spec19T 72/28
Std springs
Toe Fr=0deg, Rr 2deg
ride height Fr=5mm, Rr 5.5mm
Sway bars Fr=1.0, Rr 1.0
Shocks=1mm holes in pistons Fr 50wt, Rr 40wt.
Diff=One-Way
So-Cal
Indoor, Asphalt, High bite with banking.
Quick list...
Std springs
Diff=One-Way
So-Cal
