Barracuda from Alex racing >
Like Tree1Likes
Old 03-27-2003, 02:50 PM
  #1531
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by itchynads
I found that my shaft holders were warped so that the crown gear does not spin as freely as it should. Its causing high spots as I rotate the gear. Hopefully the alloy holders will fix this problem.
They Sure will
-Dave
JDM_DOHC_SiR is offline
Old 03-27-2003, 03:03 PM
  #1532
Originally posted by Ian
thanks dave ....no hurry on this
Ok
-Dave
Old 03-27-2003, 03:37 PM
  #1533
Herminator's Avatar
Well I've gotten round to rebuilding the cuda, the spur gear is now on the side closest to the motor, it's tightened just enough and a little thread lock was used, it still seems to wobble slightly though, seems the alloy shaft holders will be higher on my list than I thought and the center holder/motor mount. Although I still think it will be more than a close fit with the screws holding the spur gear, they should have made the extra bit sit level with the rest of the motor mount.
Steve do you stock those extra quiet spur gears you were on about? since they're thicker they sound like a good idea.
Herminator is offline
Old 03-27-2003, 04:12 PM
  #1534
Hi Hermi'
On the R2 if the the PAL motor mount/shaft holder was not offset like it is..... it would hit the Batterys!!
Unlike the R1 where the mount was not off set ...it waas just straight ..... But the screws that hold the Spur on mount from the back (side by the Diff)
No worry's my friend
-Dave
Old 03-27-2003, 04:14 PM
  #1535
TimPotter's Avatar
Trader Rating: 14 (100%+)
CAn anyone tell me what parts I will need to upgrade an R1 to an R2 ?
TimPotter is offline
Old 03-27-2003, 04:26 PM
  #1536
Herminator's Avatar
if the screws are on the side of the diff how do they hold on the spur? since it's on the othre side of the threaded flanges on the drive shaft. I see what you mean about clearing the cells though. There will probably be enough clearance for the screw heads if I use some button head titanium screws like those I use on my Lab.
back to the painting I go, lovely fumes
Old 03-27-2003, 04:29 PM
  #1537
Also look at the Pic' see how the Spur is mounted and what side the screws are installed on
BTW thats a Kimbrough Gear on there too... Ome more Secret that Steve found out... "Wider is Better"
-Dave
Old 03-27-2003, 04:36 PM
  #1538
Herminator's Avatar
ok, there you have the whole spur on the side closest to the diff, I had it like that on Monday and the pinion was strugling to reach the spur, probably causing some of the problem of stripping the spur.
Old 03-27-2003, 04:39 PM
  #1539
Herminator's Avatar
I don't see anywhere in the UK selling Kimbrough gears
Old 03-27-2003, 04:54 PM
  #1540
I'm pretty sure that the R1 will allow you to mount the spur like that but on the R2 the pinion will barely reach the spur unless you move it to the edge of the motor pinion mount.
itchynads is offline
  #1541
Thats whats messing with your head and your thinking to much about the motor mount! the [email protected] fumes j/k
-Dave
Old 03-27-2003, 04:55 PM
  #1542
Originally posted by spooky
Can anyone tell me what parts I will need to upgrade an R1 to an R2 ?....
Sure there ....
Here you go you will need the following Alex Part #s
1)6604 lower chassis
2)6630 Spur gear adaptor
3)6710 Long Span A-arms x2
4)6733 Sway bar set x2 ( use these to space the shock towers)
Also.. you can use the normal upper deck... it just has to be trimmed down with a dremel about 2mm where the spur gear mounts
[email protected]
-Dave
Old 03-27-2003, 05:20 PM
  #1543
One you all "get" the Mount/holder you will see that it will allow you to mount the Spur about dead center between the Chassis opening on the Bottom of the chassis..
-Dave
Old 03-27-2003, 06:24 PM
  #1544
Exclamation Now thats a color selection
Check out all of the new Speedway PAL/ ALEX / EXCEL alloy hubs and what colors they will be offered in!!
-Dave
Old 03-27-2003, 06:28 PM
  #1545
Herminator's Avatar
I want a car with each alloy part in a different colour
