Barracuda from Alex racing >
Like Tree1Likes
Old 03-25-2003, 03:41 PM
  #1486
Herminator's Avatar
I'm pretty certain it's the same spring then
quite handy since Modeltech sell a set of all the other RC Lab springs, something like 9 pairs for 30, they're all nicely coloured, the colour range is basicly the same as HPI springs but they are more evenly spread in stiffness.
Herminator is offline
Old 03-25-2003, 04:22 PM
  #1487
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Good Give them a try then
-Dave
JDM_DOHC_SiR is offline
Old 03-25-2003, 04:52 PM
  #1488
Thanks, sleep well, for tomorrow comes the mass order proccessing madness
Poor Steve
-Dave
Old 03-25-2003, 07:29 PM
  #1489
pkranger63's Avatar
Default Quick building question
Well I got my 'Cuda today and already got a quick question I am assembling the one way unit and there are these plastic (i think) things that go into the outdrives of the one-way. I am not sure if these are the one's that are on the shock plastic parts tree. The intructions say there are 6 of them but I am counting 8. LOL
Thanks for the help,
Matt
pkranger63 is offline
Old 03-25-2003, 07:34 PM
  #1490
andrew5's Avatar
then you have two xtra
andrew5 is offline
Old 03-25-2003, 07:35 PM
  #1491
mike_Webb's Avatar
Any chance of getting the Black Version Steve?
mike_Webb is offline
Old 03-25-2003, 07:47 PM
  #1492
Michal101's Avatar
Default Re: Quick building question
Matt
Matt,
I used the small black rubber "O" rings to go in the front one-way outdrives and this allows for some cushioning and it also keeps them somewhat aligned. I hope this helps.
Mike
Michal101 is offline
Old 03-25-2003, 07:52 PM
  #1493
pkranger63's Avatar
I will give that a try thanks.
Old 03-25-2003, 09:43 PM
  #1494
Talking
Black was a limited production run for a shop in Japan...but I'm sure that Speedway PAL can get them though... ...
Ask Steve
-Dave
Old 03-26-2003, 12:54 AM
  #1495
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Default How about a little Shock Building discussion !
I am new to the Yokomo style shocks, what is the best method, or is there one "right" way to do it ?
The kit destructions show that the pistion should be set about half-way in after bleeding the oil out of the top, is this about right? is this also an adjustment...
anyone :-)
RedBullFiXX is offline
Old 03-26-2003, 04:09 AM
  #1496
Herminator's Avatar
Matt
It's the black rubber o-rings you're meant to use, it had me confused at first, since the pictures shows a flat edge on the o-ring. All one ways use rubber o-rings it seems, to stop the drive cup from slipping too far out of the one way bearing. Don't use them all, there are some spares, it's a common thing to loose you want just enough in so that they don't interfer with the up and down travel of the suspension, as the cvd's moves in and out of the outdrive.
Old 03-26-2003, 05:39 AM
  #1497
Michal101's Avatar
Default Re: How about a little Shock Building discussion !
anyone :-)
Redbullfixx,
I really like the R2 (or Yok style) kit shocks and have found them very easy to build and get rid of the air bubbles usually on the first attempt.
Anyway, what I did was push the shock shaft almost all the way to the end of it's length and then insert the bleed screw and make sure that it is tight but do not overtighten it. Then pull the shock shaft back to it's original position and cycle it a few times to ensure that the bleeding process was done correctly.
Mike
Old 03-26-2003, 06:58 AM
  #1498
Can you comment on this new option part from Pal Dave?
Looks like a completely redesigned drive shaft system for the 'cuda:
http://www2.ocn.ne.jp/~sw-pal/Newpro...Drive/861.html
Is this the new PAL motor mount I've been hearing about??
itchynads is offline
Old 03-26-2003, 07:14 AM
  #1499
Herminator's Avatar
Try looking here
http://www.rctech.net/forum/showthre...290#post316290
whilst on the topic of this center shaft holder, it looks kind of close to the spur gear holder, will it work with the spur gear on the side closest to the motor and using the big hex head screws to hold the spur gear on?
Old 03-26-2003, 09:14 AM
  #1500
SpeedTech's Avatar
Hi Guys,
I'm back from a good night of racing at SoCal last night. We had two other guys out there with Barracuda, one of them is our team driver Dave (Redbullfix that you guys see posting on this thread). We didn't run pro-stock last night, instead everyone ran 19T in preparation for the up coming Reedy Race.
Dave basically went with the box stock setup (springs, long arm setup, and shock locations) and on his first time out, he put the R2 solid in the A-main (5th qualifier). Dave's car looks to have the most "zip" through the infield and amazing top speed down the straightaway. With a few small changes before the main, Dave's car was even better in the main, with a rough start, Dave actually was last (about half a track behind) and charge all the way through the field to take 3rd at the end. Great result for the first time out, Thank you Dave!
While Dave was on box stock setup, I tried out the mid-span arm, while the other driver tried out the front spool. The mid-span arm did exactly what Alex Racing intend it to do, faster transition side to side. Definitely good for small-mid size twisty tracks. I also tried out the rear hub carrier with less toe-in degree (Part number 6113) and the car definitely had more acceleration, I had to hold back the throttle through the infield because the car would take off so fast out of the turn.
We also tried out the spool unit in the front. Very good straight line acceleration, a slight push going into the turn, and it yanks the car through the turn on power. The only problem with the spool is that by nature, they are extremely harsh on the front drivetrain components (Universals joints, bones, and the spool itself) We began to wear a notch on the front spool after two runs but in a situation where you can not run a front one-way, a spool might be your next best bet.
In case you guys are wondeing...I qualified 10th again last night (seemed to have fallingin love with that spot or something...hahaha ) and because of a 7 car A-main, I was once again in the B. For me personally, the mid-span arm setup with the reduce toe rear hub carrier was a bit too much in responsiveness. I'm keeping the reduce toe rar hub carrier and going back next week with the long arms. We will also start testing some anti-roll bars and Alex springs. I do have the springs available (12different kinds) and I just have to figure them out first before I put them online for you guys.
I would also like to welcome Michal101, who is our team driver on the east coast. Along with Dave (JDM_DOHC_SiR), Michal101, Dave (Redbullfix) and myself, we should be able to help you guys out with any questions you guys might have
Thanks for reading!
Steve Wang
SpeedTech is offline
