Help selecting a car for speed runs >
Old 04-03-2011, 09:38 PM
blazerss's Avatar
Trader Rating: 61 (100%+)
Default Help selecting a car for speed runs
So I have kind of stumbled into making speed runs. I stick to rc boats mostly these days with the exception of a slash and firestorm. I have had a TC3 car that I turned into a drifter a while back. It has been sitting a while so I decided to throw a sidewinder and 5700 in it and see how fast it would be just to give me something to do. Well, now I'm hooked and want to go faster. I started with a 2s lipo and got bored. Went to a 3s lipo and can't keep the thing together. My problem is the TC3 wasn't meant for these speeds and parts aren't holding up. I'm in need of suggestions on what to get that can handle these speeds and abuse.
blazerss is offline
Old 04-09-2011, 08:27 PM
blazerss's Avatar
Anyone??
blazerss is offline
Old 04-09-2011, 08:37 PM
i would think any car that is decent and set up well should work just fine. i had a pretty much stock (except for electronics) xxx-s that was super fast and it all held together just fine.
cooptroop123 is offline
Old 04-09-2011, 11:12 PM
Timbulb's Avatar
I'm trying a 1/10 pan car (WGT) this year as a drag car. Way less moving parts to blow apart. I'll be using a 4.5T with up to a 4 cell lipo in it.
Timbulb is offline
Old 04-10-2011, 06:22 AM
savtraxx's Avatar
world record is set with 2 MI4's joined together , 12s lipo , NEU 1 turn motor...
savtraxx is offline
Old 04-10-2011, 07:07 AM
heretic's Avatar
apart from the center shaft wobbling the tc3 drivetrain parts are sturdy enough to withstand huge power. Just solve the shaft wobble.
I would go pan car if I would do that ( not gonna happen), but if you want to run it down your street I would advise a HPI sprint, because it has belts (efficiency increasing with speed if properly tensioned), is cheap and has steel drivetrain parts.
heretic is offline
Old 04-10-2011, 03:40 PM
blazerss's Avatar
I have already blown apart the drive cups on the TC3. They are now aluminum. They held up fine the first run, but now the stock rear cvd bone is done. I guess if I upgrade this all of the drive parts will be aluminum and so I should be ok. The center shaft wobble is something I would like to fix, any suggestions?
blazerss is offline
