servo glitching
Old 09-09-2004, 07:33 PM
ajg
Registered User
ajg's Avatar
Default servo glitching
When my car is on the servo keeps wiggling, and some times it turns to one side but still wiggles. Does it matter if the servo wire passes by the antenna?
How can I fix it?
ajg is offline
Old 09-09-2004, 07:39 PM
burbs's Avatar
is this the servo in your micro???? if it is u might not have enough power going to your electronics.. u might want to run a seperate reciever pack for your electronics.. and the main one for the motor
burbs is offline
Old 09-09-2004, 07:43 PM
ajg
Registered User
ajg's Avatar
I'm running 9.6 volts. Also, it doesn't glitch till I do a second speed run.
ajg is offline
Old 09-09-2004, 07:47 PM
Suspended
On the second run you might not have enough voltage/amperage for the servo to work properly.
tmeeks is offline
Old 09-09-2004, 07:49 PM
ajg
Registered User
ajg's Avatar
Yeah, makes sense, since it drains alot of the battery pack for one couple second long run.
Thanks guys.
ajg is offline
burbs's Avatar
ask any modified racer.. they all run reciever packs.. especially with 4 cell racing.. the further into the runtime u get the less voltage u have stored.... the lower it gets the less power to spread..
burbs is offline
Old 09-09-2004, 07:53 PM
ajg
Registered User
ajg's Avatar
Guess I can only do one run per charge.
Can I use my other battery packs (using them to power my charger) to charge my battery pack on site? Like a bump box, except charging it more.
ajg is offline
Old 09-09-2004, 07:58 PM
berger's Avatar
I would use a 12V car battery to power your charger, which i dont know what it is, maybe you should add it to your signature? Have you tried one of the magnets to help smooth the voltage to the servo, similar to the ones found on playstation pads etc to see if that helps?
berger is offline
Old 09-09-2004, 10:37 PM
burbs's Avatar
i would use 12 cell pack to power your charger if u use it as a bump box... but yes it would work
burbs is offline
Old 09-10-2004, 10:33 AM
Buy a better radio. Honestly, why waste the $1092 that you have spent on one glitch? We still want to see your verified speed run.
071crazy is offline
Old 09-10-2004, 10:52 AM
Suspended
I guess you're not a huge fan of ajg. Your signature is unbelievably funny. I've heard rumors of ajg, but I still don't see what the big deal is. I'm sure there are faster micros out there.
tmeeks is offline
Old 09-10-2004, 10:57 AM
well, I'm not lying, am I? Why see all that money go to waste because of a glitch? He has invested a lot of money into his micro, it would be a major bummer if it flew into a curb.
071crazy is offline
Old 09-10-2004, 03:29 PM
ajg
Registered User
ajg's Avatar
Hey 071crazy, we already figured out the problem, low battery mah after the first run. Also I have a different radio.
I haven't got any good runs yet (I've been doing short runs and hitting around 65mph on them), I can only get 1 run in for every couple days since I don't have much time (school and basketball practice).
ajg is offline
