Old 04-01-2011, 02:23 AM   #1
Default 150A ESC Problems
Hi!
I have an Aeolian 150A ESC (similar to HobbyKing's 150A ESC) that doesn't turn my motor any more...
It sends power to receiver all lights OK, but the motor doesn't works.
I don't have any other ESC at the moment and would like to make some test to the motor (Tekin 1900kv) to make sure the problem is from the ESC.
All this start to happen after bind the spektrum receiver using the power from the ESC... bad move or just a coincidence?
After some testing on the receiver, all channels are OK.
Can you give me some help on this? Could it be the capacitors on the ESC?
How can I test all this?
Regards!
ratax is offline   Reply With Quote
Old 04-02-2011, 05:11 AM   #2
Any help?
Old 04-02-2011, 07:42 AM   #3
MrUnlimited's Avatar
Did you hook up the motor the right way? Is there a reset button on the esc. If so you might try to reset the esc to its factory settings.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 04-02-2011, 09:00 AM   #4
Hi!
The motor is hooked just like it was the last run.
My ESC doesn't have a reset button...
If all was OK about the current passing to the motor, what values should I have on each of the three wires (for a 4s lipo)?
What is the reading I should have on capacitors?
Thanks!
Old 04-02-2011, 09:02 AM   #5
2strokin's Avatar
sweet
2strokin is offline   Reply With Quote
Hobbywing ESC's Drift_Buggy Radio and Electronics 827 03-30-2016 11:43 PM
Turnigy 150A ESC (Hobbywing, EzRun) 2350kv for 8th scale Jerrit1 Electric Off-Road 17 05-01-2011 10:51 AM
Hobbywing 150A ESC or Speed passion Arrow V2? MrUnlimited Electric Off-Road 13 03-30-2011 07:37 PM
HK 150A ESC & 1900kv (mbx5t) Redneck13x Electric Off-Road 11 06-08-2010 08:24 PM
