Rollout spreadsheets >
Old 09-09-2004, 04:05 PM
Default Rollout spreadsheets
Hey I was wondering if anyones made any large, detailed rollout spreadsheats you wouldn't mind sharing? I was going to make one but I havn't had time this week. Thanks!
psbarger is offline
Old 09-09-2004, 04:14 PM
mo
mo's Avatar
www.gearchart.com
mo is offline
Old 09-09-2004, 05:15 PM
Ortiz's Avatar
Check your PM...
Ortiz is offline
Old 09-09-2004, 05:58 PM
raving-monkey's Avatar
something aint right on that website.
i worked out the speed for my 12th pan car and i selected pan car in the thing, entered 72/22 spur/pinion that i use, 52mm tyres, 25k revving motor, and it said it went something like 45mph
but then again its good for working out rollout
raving-monkey is offline
Old 09-09-2004, 09:06 PM
HarshGuy's Avatar
Remember that's the "theoretical maximum" speed based on Rollout, doesn't factor anything else in but the simple math.
HarshGuy is offline
Old 09-09-2004, 09:41 PM
Got exactly what I was looking for from Ortiz, thanks!
psbarger is offline
Old 09-10-2004, 08:51 AM
jaysimpson's Avatar
Here is one in excell written by John Stranahan. Some may remember John from Tech Talk. He was very knowledgable about car setup. It has been altered a little bit by John Fontaine.
It is easy to use just input your internal drive,tire size (in MM),and you can also change the pinion spur numbers if you need to and it will adjust the totals as you go.
File Type: zip
jaysimpson is offline
Old 09-10-2004, 09:27 AM
TigeRyan's Avatar
You could also try this one that I did in flash...works pretty good you can flip the numbers around several ways....
http://www.sixfoottiger.com/content/...lculator.index
TigeRyan is offline
