Old 03-31-2011, 05:12 AM   #1
spencehotbodies's Avatar
Default hara springs....
Hello
Hope some one can help..............................I run hara springs but the paint dots have come off, is there any way of measuring them to see what there are?
spencehotbodies is offline   Reply With Quote
Old 03-31-2011, 05:30 AM   #2
PizzaDude's Avatar
Originally Posted by spencehotbodies View Post
Hello
Spring tension differs either by wire thickness or no of coils usually.
Hope this helps.
PizzaDude is offline   Reply With Quote
Old 03-31-2011, 06:03 AM   #3
Default HARA SPRINGS
Cheers
You don't no what this measurement stands for 14x25x1.5mm 6.25 coils (pink / 2pcs) 320 gf/mm?
Old 03-31-2011, 06:09 AM   #4
PizzaDude's Avatar
Cheers
Six complete coils and a quarter of 1.5mm wire
Pressure rating 320 gram-force per millimeter.
Old 04-01-2011, 04:18 AM   #5
Monkeys punk's Avatar
I had the same problem with the Hpi pro 4 springs. I just squeeze two together and the one that compress first is the softer. It takes a while but works surprisingly well.
Monkeys punk is offline   Reply With Quote
Old 04-01-2011, 05:16 AM   #6
Cheers
I counted the coils, that seems the best way.
Old 04-01-2011, 09:25 PM   #7
Trader Rating: 20 (100%+)
I had that problem too. Before it got worst, I painted 1/4 the spring its color so I would'nt lose track of the spring rate
goots is offline   Reply With Quote
NEW D8 Atsushi Hara Edition* Atrackstar101 Nitro Off-Road 5998 05-13-2016 01:24 AM
1/12 RS12G Atsushi Hara Replica Barry White Electric On-Road 683 11-16-2007 10:19 PM
Hara Spring Rate Chart? Skiddins Electric On-Road 9 10-21-2007 05:28 AM
