Old 03-29-2011, 07:18 AM   #1
Default help mounting shells
i was wondering what is the best way to make marks for the body posts on the plastic shell. i got some bodies that are painted so i cannot see through to mark the body post position.
omegaf is offline   Reply With Quote
Old 03-29-2011, 07:30 AM   #2
digitrc's Avatar
I recently got some pointed markers sold under the Fastrax brand here in the UK.
They sit on top of the body post and will make a mark in the paint/body where you need to cut.
David Allen - www.digitrc.co.uk - Xevo - Much-More Racing UK
digitrc is offline   Reply With Quote
Old 03-29-2011, 07:32 AM   #3
Skiddins's Avatar
ANother way to help make sure the bodyshell is centred is to use wide hexes and/or wheel shims so the wheels touch the inside of the shell (without the wheelarches cut yet).
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-29-2011, 08:43 AM   #4
cool, but not it seems i will have to make another purchase
i bought those little pointed markers and while i was at it i got me an e-revo brushless
Old 03-29-2011, 02:56 PM   #5
These are really great
http://www.tonisport.de/shop/tonispo...et-system.html
sidecarphil1 is offline   Reply With Quote
Old 03-29-2011, 03:22 PM   #6
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
i have found these to be very helpful with painted bodies
http://www.integy.com/st_prod.html?p...218&p_catid=44
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 03-29-2011, 04:36 PM   #7
The poor racers way to mark the posts. Put a small dab of paint or liquid paper on the tops of the body posts, then carefully position the body over the body posts so the paint marks the spots under the body. Good Luck!!!!!!
mooby64 is offline   Reply With Quote
Old 03-29-2011, 07:43 PM   #8
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Ofcourse, once you get one body right, you can use it as a template for your other bodies (assuming you are using the same style of body for all of them). Put the old one with the holes in it underneath or above the new one to be drilled, and make your hole marks. I have used the "poor man" technique too with a dab of paint on the posts.
nf_ekt is offline   Reply With Quote
Old 03-29-2011, 09:01 PM   #9
hacker's Avatar
Trader Rating: 141 (100%+)
I just put a clear body on top of the posts, and mark the holes out with a needle/drill bit , drill them out, and then paint.
hacker is offline   Reply With Quote
Old 03-29-2011, 09:15 PM   #10
nf_ekt's Avatar
I think the problem is that his shells are already painted...
Old 03-29-2011, 09:17 PM   #11
hacker's Avatar
oh yes, helps to read the first post haha
sorry, yes the paint on post method would work best in this situ then
1/12 forum ovalnator Electric On-Road 46175 Today 11:55 AM
Tamiya TRF417 kentech Electric On-Road 6522 09-30-2017 04:06 AM
RCGT Pics & Paint ONLY! Show them off! reenmachine Electric On-Road 1135 10-01-2016 08:42 AM
Shepherd V8 '09 Josh Cyrul Nitro On-Road 400 10-13-2011 07:09 AM
