Old 03-29-2011, 06:04 PM   #16
I bend up wheels quite a bit
Old 03-29-2011, 06:18 PM   #17
Me 2
Thats why I use setup wheels 2 set my camber, then I see what it is on my setup station.
Works 4 me
Lazer Guy is offline   Reply With Quote
Old 03-29-2011, 06:25 PM   #18
CraigM's Avatar
Trader Rating: 34 (100%+)
You'll get the most consistent car by using both, setup station then camber gauge. The setup station is the only way to set toe accurately, and also gets you in the ballpark for camber. Then once you have your tyres mounted up do the final check with the camber gauge.
As people have mentioned, wheels and tyres can be warped, bent, wobble, etc. The best thing to do is to take 3 or so readings with the gauge and make sure the average is what you want your final camber to be. This is how Jilles Groskamp does it as seen in his pro-tips video
+ YouTube Video
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-29-2011, 07:14 PM   #19
kyle133's Avatar
setup wheels and camber gauge is what I use. gets rid of the out of round wheel problem, and is very accurate
ACTION HOBBIES KINGSVILLE
MT POCKETS RACING
kyle133 is offline   Reply With Quote
Old 03-29-2011, 07:30 PM   #20
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Set station for toe, definitly. Everything else with the basic tools. I never felt I totally got the car right just using the station.
nf_ekt is offline   Reply With Quote
Old 03-30-2011, 04:51 AM   #21
Edgar_P's Avatar
For setting toe I always use my digital calipers. I measure front and rear distance between front wheels. 1.8mm difference gives about 1 degree of toe. By using this method I have almost forgotten about setup station.
BMI COPPERHEAD 12
Edgar_P is offline   Reply With Quote
Old 03-30-2011, 05:14 AM   #22
trerc's Avatar
Trader Rating: 89 (100%+)
Yea but at some point you put wheels back on the car, I don't know any classes where set up wheels are legal (except maybe in mod ) and even then I think traction rolling may be an issue...
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 03-30-2011, 06:46 AM   #23
HUDY setup station is 0.5 less than Yokomo camber gauge... compared too with Team Associated and TeamC camber gauge... they gave same result...
zamrioo2 is offline   Reply With Quote
Old 03-30-2011, 07:24 AM   #24
IMHO
What ever gauge or tool you use to do your setup with has to repeat.
If you get different readings every time it could be the gauge or your car so you need to know for sure your gauge is right.
Roll Centre and Camber Gain Calculator BobW Electric On-Road 181 12-31-2011 08:37 AM
SC10 Camber Measurement Mototech Electric Off-Road 8 12-13-2010 12:28 PM
F/S: Glow plug igniter, gel cell charger, gel cell, camber guage and car stand PD2 R/C Items: For Sale/Trade 18 05-21-2007 04:07 PM
Full set AE allen drivers, battery jig, discharger, camber gauge, gear cover cpolaris502 R/C Items: For Sale/Trade 8 02-28-2007 04:54 PM
