Closed Thread
Old 09-08-2004, 01:20 AM   #1
Default New Reedy TI With aliminium Endbell
Has anybody seen or heard about this motor??
I didnt think it would be long untill Reedy to come out with a motor to conquer the V2s if they can.
Anyway should be interesting and would be good to get peoples view on thse motors.
Dik Yarx is offline
Old 09-08-2004, 01:28 AM   #2
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I only see one advantage to an aluminum endbell. It will act as a heat sink, especially for the brushes/com. Other than that, I don't see any other advantages for RC applications.
We have been using aluminumb endbells in high end slot car motors for over 15 years now. The slot industry had to make the change because the motors get so hot we were actually melting the endbells. At the time we were actualy using plastic that melted between 425-500 degrees!! RC motors dont get that hot.
It is also good that the slot industry has done the R&D on the best way to anodize and insulate the endbell. Remember that aluminum conducts and if the two brushes and the hardware aren't insulated then the motor becomes one big short circuit. That was a common problem with early alum slot endbells.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline
Old 09-08-2004, 01:44 AM   #3
Wency_TA03R-PRO's Avatar
Exclamation
yup! you're right about that.. that problem might arise although we know that aluminum materials is a poor conductor of electricity but still electricity can pass through it. less amount of electricity may only pass through the other end...
Wency_TA03R-PRO is offline
Old 09-08-2004, 02:20 AM   #4
Andrew Swanson's Avatar
Send a message via AIM to Andrew Swanson Send a message via Yahoo to Andrew Swanson
Like Scott said if the aluminium isn't insulated corrctly the whole entire endbell becomes a short circuit. (big problem with the V2 design which causes your speedo wires to come off!!)
The aluminium does act as a heat sink for a little bit, but once it is warm it traps too much heat. Another problem with the V2 is it traps in heat like a oven thats why the factory guys cut large holes and slots in their V2 endbells. And use HIGH TEMP solder on their wires!
But if the endbel as sufficent air flow through it the aluminum will work well.
Andrew Swanson is offline
Old 09-08-2004, 02:25 AM   #5
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
i though the V2 endbell might have a heat problem like that, looks like i will be giving my V2's the cnc treatment when i get them. i wonder if this will be legal (ifmar, roar etc)
dontfeelcold is offline
Old 09-08-2004, 03:52 AM   #6
fatdoggy's Avatar
R/C Tech Charter Subscriber
I've heard orion is having some problems with the solder on their arms melting and it is good for around 600*...(according to bj) I'd rather see an endbell that uses stand-up brushes at 45* and standard springs instead of an Alum endbell. The only time I've ever melted a composite endbell was when I shot 12v into a stock motor.
fatdoggy is offline
Old 09-08-2004, 09:34 AM   #7
Rick Hohwart's Avatar
Originally posted by Andrew Swanson
like scott said if the aluminum isnt insulated corrctly you get lots of shorts (big problem with the V2 design which causes your speedo wires to come off!!)
Also the aluminum does act as a heat sink for a likttle bit but once its warm it traps too much heat. Another problem with the V2 is it traps in heat like a oven thats why the factory guys cut large holes and slots in their V2 endbells.
Really? I had no idea you are such an expert. Engineering degree? from where?
I have actually never had a wire come unsoldered, never used a fan, and use the stock endbell. No problems here. The 10,000+ customers who have bought one are pretty satisifed, as are the drivers who are winning about every big race worldwide.
You are simply not a very good driver, and have to blame something or someone other than yourself for your poor results.
Rick Hohwart is offline
Old 09-08-2004, 09:44 AM   #8
Matt Howard's Avatar
wow
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline
Old 09-08-2004, 09:47 AM   #9
i agree 100%
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline
Old 09-08-2004, 09:54 AM   #10
The Evicerator
Wow!
I love the internet
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline
Old 09-08-2004, 10:30 AM   #11
dizzy1's Avatar
Trader Rating: 24 (100%+)
NICE!!!!!!!!!
Looks like the bass boat has a leak.
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline
Old 09-08-2004, 11:12 AM   #12
Kenshin's Avatar
Pass the popcorn please...
Kenshin is offline
Old 09-08-2004, 11:20 AM   #13
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Does anyone have pic or info on the new Reedy Motor, as this is what the topic of the thread is.
But
The only problems I have had with the motor wires coming unsoldered, was because they were not soldered properly in the first place.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline
Old 09-08-2004, 11:38 AM   #14
wagonman72's Avatar
I like my Kisbey Modifieds motors alot. They go real fast.
wagonman72 is offline
Old 09-08-2004, 11:41 AM   #15
Forget a degree he probably doesnt even have a diploma.From the way he spells, looks as if driving isnt his only problem. See kids stay in school dont become a R/C drop out flunkie.
mosieur is offline
Closed Thread
WTB - 19t V Endbell motor Shev Australia Wanted to Buy 0 03-02-2008 07:47 PM
WTB CheckPoint Endbell and Cobalt 2 Endbell mike ivy R/C Items: Wanted to Buy 1 10-19-2006 11:39 PM
Reedy Quad Mag Orion V2 Endbell sampaio Electric On-Road 10 03-06-2006 10:58 AM
I need help with the V2 Endbell trf_racer Electric On-Road 6 11-27-2005 06:13 AM
Aluminium Endbell rcprix Electric On-Road 14 06-03-2003 09:23 AM
