Old 03-27-2011, 05:14 PM   #1
FastPete's Avatar
Trader Rating: 44 (100%+)
Default Xray T3 verses T3R whats the difference
Looking for my first 1/10 touring car. To run a 17.5 class, and open.Got my eye on Xray.Would like to know the difference between these for the price difference? Or anyother suggestions.
Thank You
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 03-27-2011, 05:31 PM   #2
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
T3 '11 has these things that the R does not
easily adjustable Turnbuckles
aluminum rear diff oudrives
CF chassis, top deck, and towers
If it were my money I would go T3r.
Old 03-27-2011, 05:43 PM   #3
FastPete's Avatar
Thanks just found a T3R thread....Are the parts that break the same? My LHS stocks T3 stuff. Just afraid I will upgrade anyways and have the same money into it.lol
Old 03-27-2011, 05:50 PM   #4
t3r has the single point steering and t3 2011 is the dual bellcrank.
biggest difference other than that is chassis material and the fact that the t3r doesnt have turnbuckles
the t3r will have a bit more flex in the chassis than a standard t3 or t3 2011
Dondor is offline   Reply With Quote
Old 03-27-2011, 06:23 PM   #5
FastPete's Avatar
Looking on their site. The only two things that bother me is..
Aluminum dogbones? Will they just bend eaiser?
And the turnbuckles non adjustable? Are they threaded? I see you cant put a wrench on them
Old 03-27-2011, 06:56 PM   #6
It is just threaded rod.
Old 03-27-2011, 07:21 PM   #7
BadSign's Avatar
Trader Rating: 15 (100%+)
I run a T3R here in Indy. It performs just as well as the 2010 T3 it's based on. I added turnbuckles (which weren't a necessity), and the chassis posts, which you absolutely need. On a high speed corner the chassis can flex so much the steering post pops out without the aluminum spacers, so I'd definately pick those up.
You can't beat that car for the price. It's great.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 03-27-2011, 07:23 PM   #8
nashrcracer's Avatar
R/C Tech Charter Subscriber
the T3r can be competive
The alum rear axles are fine in the rear. the front are not it your running 17.5 get the 52mm spring steel for the front. wait till you break them though. running 21.5 or 25.5 they might be ok. I got the brace standoff for the center right after the steering as a good hit might pop out the steering link. the adjustable rods are not critical I put a setup on it and left it.
I run it at club races and don't get beat offen other then by Eric Anderson.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 03-27-2011, 07:50 PM   #9
FastPete's Avatar
Thanks guys alot of good info...Its totally upgradable to T3 2011? As things break or have issues.
And are the swaybars needed?
Thanks Again. Still trying to deside
Old 03-27-2011, 08:39 PM   #10
301131 is the 2011 upgrade kit for about $190 and it is full on but the sway bars. I am not running sway bars. but it does help.
Old 03-27-2011, 09:55 PM   #11
I didn't know y'all allowed 2 car heats at your track Dirla! lol jk
Old 03-28-2011, 06:45 PM   #12
FastPete's Avatar
Thanks for the input...Think im going to save for the real deal. Unless I can find one used.
Thanks again
