Xray T3 verses T3R whats the difference
I run a T3R here in Indy. It performs just as well as the 2010 T3 it's based on. I added turnbuckles (which weren't a necessity), and the chassis posts, which you absolutely need. On a high speed corner the chassis can flex so much the steering post pops out without the aluminum spacers, so I'd definately pick those up.
You can't beat that car for the price. It's great.
the T3r can be competive
The alum rear axles are fine in the rear. the front are not it your running 17.5 get the 52mm spring steel for the front. wait till you break them though. running 21.5 or 25.5 they might be ok. I got the brace standoff for the center right after the steering as a good hit might pop out the steering link. the adjustable rods are not critical I put a setup on it and left it.
I run it at club races and don't get beat offen other then by Eric Anderson.
I didn't know y'all allowed 2 car heats at your track Dirla! lol jk
