Old 03-24-2011, 03:27 PM   #1
Default Tekin RS Pro Overheating
Hi, I am running a Tekin RS Pro with an Nosram 3.5 T PURE Evo BL Modified motor, with Spektrum DX3s
Problem: When I run for about 10 mins the car fails to respond to my radio signal, all the LEDS are flashing. I assume and read that it is a problem with overheating and not a binding issue.
The question I have is, how do I make it run cooler? Either without buying new stuff (prefered, obviously) or buying a higher turn motor, or buying something that would help, cheers.
tjfmuk is offline   Reply With Quote
Old 03-24-2011, 03:31 PM   #2
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
That esc can't even dream of running 3.5's
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 03-24-2011, 04:10 PM   #3
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
add a second cap,10 min is a long time
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-24-2011, 04:11 PM   #4
Timbulb's Avatar
Shitty soldering job?
The soldering posts are the heat sink so make sure they're clear and have some airflow over them.
The RS Pro can run 3.5, but if it's not geared properly it'll get hot. Is the motor getting hot as well? If the motor is still cool, try gearing it up.
Timbulb is offline   Reply With Quote
Old 03-24-2011, 04:17 PM   #5
The RS Pro can handle 3.5T, but only just. 10min is a no-go IMO.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 03-24-2011, 04:26 PM   #6
Thanks for the responses. What motor would you recommend to run it? Or what esc would go well with the 3.5 t motor.
I bought it cos it said there was no motor limit on it, how then is 3.5t too much for it? I had the same motor running on nosram matrix okay.....
Old 03-24-2011, 04:29 PM   #7
You can use the current limit
Manson is offline   Reply With Quote
Old 03-24-2011, 04:55 PM   #8
snellemin's Avatar
Trader Rating: 16 (100%+)
My buddy use to run a 2.5T with the rspro in a truck. He had a fan blowing over the solder post and a capacitor bank.
I ran a 3T x12 LRP with the MMpro. I added a heatsink and cap bank on mine.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 03-25-2011, 10:47 AM   #9
JayL's Avatar
that is a racing esc made for 5-6 minute races
running anything with a 3.5 for 10 minutes, we don't race that long, is going to get hot
also you might notice even in racing at say the nationals or reedy race you don't see people , especially sponsored ones, running tekin in mod, they ALL run stock
JayL is offline   Reply With Quote
Old 03-25-2011, 02:28 PM   #10
Team Tekin
TY@TEAMTEKIN's Avatar
What does your onboad temp monitor read after the all LED sequence quits flashing and it goes back to neutral?
This doesn't add up to overheating, when the RSPro thermals it shuts down and all LEDs go dim. If they are all flashing, that means it isn't seeing a radio signal.
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 03-25-2011, 05:41 PM   #11
10 minutes is good. Mine used to thermal at 8 minutes with a 3.5 even with the 2nd cap. I never got around to running a fan facing the heat sink posts and just stopped trying to run it that long with that much motor.
spongerX is offline   Reply With Quote
Old 03-25-2011, 06:14 PM   #12
How does that not catch fire?
Old 03-26-2011, 09:57 AM   #13
Suspended
Since you already own a Rs pro, I would suggest a high speed fan , two capacitors , gear two teeth lower , lower the total motor timing to 60 or less, and time your run to five minutes max . Finally you can wax your car body , the underside of the chassis, and the wheels ,to cut down drag.... If all of the above don't work, get a tekin Rx8 !!!!
bertrandsv87 is offline   Reply With Quote
Old 03-28-2011, 09:56 AM   #14
Team Tekin
Because when properly setup the RSPro can run 4.5 and 3.5T mod motors. You can't strap up a setup for full mod to make it 6-8 minutes and expect it to make it for an entire battery pack. There are limits.
Ty Campbell
Old 04-03-2011, 03:08 PM   #15
Monkeys punk's Avatar
I have a temp sensor on mine running off my Spektrum DX3s and with 5.5 1s its hitting 65deg after 8mins but what is the max they will handle before they thermal ? If i know I can set my warning on my tranny.
Monkeys punk is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Any TIPS on soldering up a TEKIN RS Pro?? intron Electric Off-Road 26 10-16-2010 02:07 PM
HELP: Mod 4wd, tekin rs pro, SP 7.5R... it's stock slow.. teeforb Electric Off-Road 23 09-22-2010 12:21 PM
TEKIN RS PRO QUESTION??? bluebon88 Radio and Electronics 8 09-20-2010 11:39 PM
