WRC Racing F-One >
WRC Racing F-One
Like Tree16Likes
WRC Racing F-One
Old 03-12-2018, 04:52 PM
  #316
Originally Posted by RKeasler View Post
Yeah loosen during run, had to add conical washers to get it to even tighten enough to get around the track one time. Didn't have the problem 2 weeks earlier on gray carpet. I'll look up thr post you refer to.
Hope you get it to where it works for you. We tried our best with what was there. Good luck with it.
freebird is offline
Old 03-12-2018, 10:06 PM
  #317
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Hey believe me I appreciate the effort you put into it. I will get it figured out the F104 diff works the same so I may go that way in the end. Thanks again
RKeasler is offline
Old 03-13-2018, 02:34 AM
  #318
Regional Moderator
disaster999's Avatar
use a different lock nut...the stock ones they provide absolutely suck
Rick Vessell likes this.
disaster999 is offline
Old 03-13-2018, 07:27 AM
  #319
Rick Vessell's Avatar
Were you using the stock steel axle?
Rick Vessell is offline
Old 03-13-2018, 05:47 PM
  #320
RKeasler's Avatar
Yes
RKeasler is offline
Old 03-18-2018, 07:06 AM
  #321
scirocco14's Avatar
After getting the car and looking at it, it turns out the thrust bearing wasn't assembled correctly. Once getting all the parts in the correct order, and adding a small, thin washer underneath the locknut, everything works great. The thrust bearing washers are different, and the one with the larger hole goes to the inside, per the diagram. The thrust bearing washer with the smaller hole goes to the outside.
I've found with this diff, and the Associated F6 diff, if you do the following it works better.
The suggested pattern for the cupped belleville washers is this: () up against the thrust washer []. NUT ()[]
I add a thin washer under the nut and switch it to the following: NUT | )( [].
This seems to allow for a better tensioning of the thrust washer and gives a little more adjustment range.
I hope that makes sense.
scirocco14 is offline
Old 03-18-2018, 10:38 AM
  #322
RKeasler's Avatar
You are the man, sorry I couldn't hang longer but my Grandma turned 101 yesterday and we were running late for a family get together , thanks for the help.
scirocco14 likes this.
RKeasler is offline
Old 10-26-2018, 06:02 AM
  #323
Default new x-ray rear diff conversion to the WRC F1 car
has anyone made the attempt to convert the xray rear diff for the wrc f1 cars if so like to see some pics post them up.
old Axis II is offline
Old 10-26-2018, 08:11 PM
  #324
Regional Moderator
I havent and dont have any plans to, but its not too hard. Exotek have a metric to imperial bearing adapter which will fit the WRC, the rest is just an easy swap
Old 10-29-2018, 06:23 AM
  #325
If anyone is looking for a car mine is up for sale. PM me for details. Very low time on carpet only.
