WRC Racing F-One >
WRC Racing F-One
Like Tree16Likes
WRC Racing F-One
Old 12-18-2017, 08:12 AM
  #301
Scionara05's Avatar
This car is just growing on me more and more Everytime I race it now that there is more than just myself running it now at my track and can bounce ideas off other guys and get results.
I ran the car yesterday at 360v2 and was able to have myself and another f1 in the feild. Starting 9th to finish 6th just missed out on hardware after fighting a rough start.
Rick Vessell and jpx like this.
Scionara05 is offline
Old 12-18-2017, 05:07 PM
  #302
ThrottleKing's Avatar
Trader Rating: 19 (100%+)
What all would be necessary to change the LM16 to F1? Iím curious cause We donít run LM around here and I either want to get rid of it or convert it. LM looks neat but Iíve only ran it a couple times . Donít really need another F1 but Iím curious what it needs. Only thing I did to it was get a spur adapter to run any pan car spur.
ThrottleKing is offline
Old 12-18-2017, 05:20 PM
  #303
Scionara05's Avatar
Front and rear wings battery top plate AND battery mounts body
That should be just about it
Rick Vessell likes this.
Old 12-29-2017, 11:53 AM
  #304
jpx
jpx's Avatar
Originally Posted by NutDriver View Post
A friend of mine made a piece out of nylon that replaced the two tubes that attach the aluminum blocks for the rear axle. Allowed him to use any kind of rear wing (aside from the WRC). I've always wondered if the Tamiya piece would work. (Bottom-left plastic piece in the pic in the link).
https://www.tqrcracing.com/shop/prod....asp?p_id=1048
Sorry, took me some time to get back to RC ...
I have an old F103 and just tried to mount this part to my WRC - the part is a perfect fit as you can see in the pictures
So at least there is an easy solution to fit all other rear wings.
For the front it might be a different story ...
Attached Thumbnails WRC Racing F-One-07f91557-b836-41e8-917e-98a332ff5c26.jpeg   WRC Racing F-One-520c2c59-2e67-47db-854b-a5eac14e871d.jpeg
jpx is offline
Old 02-11-2018, 12:33 PM
  #305
i have the new wrc lm16 1.2 car what turnbuckle are you using and ball cap hope to hear from you soon.
old Axis II is offline
Old 02-11-2018, 07:08 PM
  #306
i have the new wrc car f1 i like to run diffrent spur gears is the adapter if so can you give a parts number hope to hear from you soon thank you for this matter.
Old 02-12-2018, 12:55 AM
  #307
Ph3nyx's Avatar
you can use Tamiya (#54215) F104 Spur Gear Spacer
Ph3nyx is offline
Old 02-12-2018, 08:19 AM
  #308
jpx
jpx's Avatar
Original turnbuckles and ballcaps worked well for me the last years whole outdoor season!
old Axis II likes this.
jpx is offline
Old 02-16-2018, 07:39 AM
  #309
Scionara05's Avatar
Well I'm ganna be putting my 016 f1 up for sale 250 with a motiv 25.5 and savox lowpro servo with all the running parts for it.
Life getting the best of me
Old 03-11-2018, 05:51 PM
  #310
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Guys had my donated '16 at the Nats this past week, could not get the diff to hold a setting at all, and I had some people that are diff experts that couldn't fix it. Didn't see anything obvious missing but something had to be. Are there any diff sets from another manufacturer that will fit, the offsets spur makes it different from Associated and the like. Any ideas?
RKeasler is offline
Old 03-11-2018, 07:08 PM
  #311
scirocco14's Avatar
Hi Rodney,
Bring it to Easley next Saturday. I'll take a look at it. I've built a couple of the WRC cars before.
Mark C
scirocco14 is offline
Old 03-11-2018, 07:21 PM
  #312
RKeasler's Avatar
Ok cool I will...
RKeasler is offline
Old 03-12-2018, 08:44 AM
  #313
Rick Vessell's Avatar
Wouldn't hold setting? Loosen during the run or??
Did you try the setup I posted in the other thread?
Rick Vessell is offline
Old 03-12-2018, 09:37 AM
  #314
Scionara05's Avatar
I race at 360 and with that carpet no wrc drivers were running open diffs it is either locked or has very little slip using the Traxxas slipper pegs
Old 03-12-2018, 02:16 PM
  #315
RKeasler's Avatar
Yeah loosen during run, had to add conical washers to get it to even tighten enough to get around the track one time. Didn't have the problem 2 weeks earlier on gray carpet. I'll look up thr post you refer to.
RKeasler is offline
