TRF Tools with Hudy Tips... can it be done? >
Old 09-05-2004, 01:05 PM
Runin Ronin's Avatar
Default TRF Tools with Hudy Tips... can it be done?
Hey Guys, So I broke the tip off of one of my TRF Allen drivers. Can I put in a replacement HUDY tip on it? Anyone tried this?
Thanks,
John
Runin Ronin is offline
Old 09-05-2004, 01:59 PM
Korey Harbke's Avatar
I think so, I have a friend that has done it. I never got to take a look at them though. I'm going to see if they work as well, because the design of the wrenches is very similar.
-Korey
Korey Harbke is offline
Old 09-05-2004, 02:47 PM
forty6's Avatar
Default Re: TRF Tools with Hudy Tips... can it be done?
Thanks,
John
Measure the shaft of the TRF tool and what size of the tip and I can compare it to my Hudy.
forty6 is offline
Old 09-05-2004, 04:22 PM
hierog's Avatar
Default trf tools
As TRF tools are possibly the best made, i can't believe you have broken a tip. I've had mine for almost a year now and nothing has happened.
just giving you a hard time Ronin! Have you tried to contact Tamiya? I bet they'd sell you a new one!
vic
hierog is offline
Old 09-05-2004, 06:17 PM
Thanks heirog, I knew you'd give me a hard time. Tamiya is closed for the holiday, I'll call them on Tuesday. I am just figuring if the HUDY tips fit, then I'll go fot them since (from what I understand) the Hudy tips are made of steel and the TRF tips are made of aluminum. Someone correct me if I'm wrong.
Old 09-06-2004, 09:14 AM
Default Re: Re: TRF Tools with Hudy Tips... can it be done?
forty6,
I just now had the time to take a pic:
The width of the shaft is .118 (3mm)
and if it matters, I broke the 1.5mm tip.
Thanks for your help.
John
Old 09-06-2004, 09:41 AM
forty6's Avatar
The shaft diameter on the Hudy is 2.98mm, so it should fit the TRF handle just fine. It is also a 1.5mm tip by the way. It also has a flat spot for the set screw. Hope this helps.
forty6 is offline
Old 09-06-2004, 10:07 AM
PERFECT! Thanks forty6...
Now the new question is where can I buy the HUDY replacement tips? Any suggestions?
Old 09-06-2004, 12:05 PM
forty6's Avatar
http://horizon.hobbyshopnow.com/serv...=NOPRODUCTPAGE
forty6 is offline
Old 09-06-2004, 12:07 PM
Rob Mincey's Avatar
ashfordhobby.com has good prices on Hudy stuff as well.
Rob
Rob Mincey is offline
Old 09-06-2004, 01:14 PM
SWEET!
Thanks guys!
