XRAY THRUST F3-8 3x8x3.5 OPTIONS? OR GEAR DIFF? >
Old 03-22-2011, 01:25 PM
gonzo416's Avatar
Trader Rating: 39 (98%+)
Default XRAY THRUST F3-8 3x8x3.5 OPTIONS? OR GEAR DIFF?
Looking for a good replacement thrust bearing for XRAY.
I found some, but I don't know if they are worth using:
http://www.avidrc.com/product/13/thr...-bearings.html
http://www.tsutsuna-racing.de/produc...526cf4c59590fb
I don't know how often they should be replaced and Xray's are a little pricey to be replacing regularly. I would think the bearings would last a while but the rings get worn pretty quick. It would be nice to be able to buy the rings but I can't find them anywhere.
I just put together the AvidRc thrust washers with the Xray thrust bearing. I'm going to give it a try. Hopefully it works good. The washers have a groove in them but when it's together with the bearing it's the same size as Xray's assembly.
gonzo416 is offline
Old 03-22-2011, 07:47 PM
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Hi Gonzo - I know that Paul L replaces his thrust bearings on a ratio of 7:1 as compared to diff rings. I had luck with avid, and mcmaster replacements. I would rebuild my diff every two weeks and throw out the thrust every month. I believe Paul doest that much more frequently but then again he runs mod. I put on new rings every 4 myths. Just sand them on 1000 grit every rebuild. I can sand the thrust plates too.
hanulec is offline
Old 03-22-2011, 08:16 PM
gonzo416's Avatar
Thanks Hanulec. Do you use the bearings that come with the thrust assembly from avid? I put an assembly together using the xray thrust bearing with avid's grooved thrust washers. Gonna see how they go this week. I just think the thrust washers take a beating. What do you use to lubricate the thrust bearing?
gonzo416 is offline
Old 03-23-2011, 07:37 PM
hanulec's Avatar
I've only used the complete thrusts. I've never tried popping the little balls out and replacing them - or swapping rings with other thrusts.
Associated or losi black grease is what u use on the thrust. Associated silicon on the balls.
hanulec is offline
