TRF416X no rear grip
Hi im running my TRF 416x on a hall/Gym floor with really low grip and my rear end has no grip what so ever could anyone advise
Setup
Standard setup out the manual
with 2 degress camber on Front and rear
and Steering is toeing out 1.5 degress
tyres Schumacer mini pins yellow compound
My front grips no issues
Kind Regards
PS its that bad that when i go round a corner it more or less will donut.
Ric
Setup
Kind Regards
Ric
Setup
Kind Regards
Ric
Setup
Kind Regards
Ric
That should give less steering and generate more rear grip.
Using a differential on the front may also help.
Setup
Kind Regards
Ric
Setup
Kind Regards
Ric
Setup
Kind Regards
Ric
Setup
Kind Regards
Ric
a quick fix would be to try removing the rear roll bar. If your on kit springs as well, you may want to go softer on the rear. Can also try removing the shims from underneath the rear suspension blocks (remember to re-set your droop).
Just some initial suggestions.
Ed
Make sure your rear diff is not over tightened
I was at a race recently where rear traction was pretty bad, but steering was good. The only thing (at the time) that made the car better was gluing the front sidewalls. I still had enough steering, but the rear grip issue went away. I need to get my hands on some springs harder than the whites, 'cause I think there's something to fixing rear grip by taking traction away from the front. These cars TURN.
Thanks guys I'll give all that ago and let you know but it wont be until 2nd cheers.
Ric
Ric
TryHard - it's donutting when coming out the corners or about 3 quaters of the way round it's a real pain. Also if my diff was to lose could this cause it. I'm new to RC Racing and this is my first TRF.
Front sticks like clue and goes like stink of the straights.
Ric
Ric
How much front droop also how does this affect the handling.
Ric
Ric
Hey guys I did as you said added more front droop and reduced back also removed roll bar and it seems to have fixed most of the issue handled alot better.
Thanks for the help
Ric.
Thanks for the help
Ric.
