which brushes :confused: >
Old 09-04-2004, 02:40 PM
pro4racer's Avatar
Default which brushes :confused:
hi
does any1 know the best brushes to use in a matrix v10 hi rpm stock motor.
i use it in a pro4 geard at 98 spur 33 pinion on a medium but open track
pro4racer is offline
Old 09-04-2004, 03:38 PM
Korey Harbke's Avatar
I'm going to assume they are laydown brushes, so a Reedy 767 is always a good place to start on any stock motor . Hope this helps.
-Korey
Korey Harbke is offline
Old 09-04-2004, 05:18 PM
pro4racer's Avatar
ok thanks ill try that 1 cheers
Old 09-04-2004, 06:33 PM
EddieO's Avatar
Reedy 767 is always the place to start on non-trinity motors.....you can always try the Reedy 766 or a 767 on the positive and 766 on the negative.
If you don't mind additional comm wear, you can try the putnam green.
Later EddieO
EddieO is offline
Old 09-04-2004, 06:38 PM
TryHard's Avatar
currently I'm running CS silver brushes in my Monster. Had to re-cut them for laydown, but they are pretty damm awesome, loadsa power, and hardly any comm wear, which is stunning, very impressed so far.
Hope it helps
Ed
TryHard is offline
Old 09-04-2004, 06:44 PM
EddieO's Avatar
CS brushes are very good....just super pricey at $10+ a pair...
Later EddieO
EddieO is offline
Old 09-04-2004, 07:25 PM
TryHard's Avatar
but they do last forever....
TryHard is offline
Old 09-04-2004, 07:30 PM
EddieO's Avatar
They do, assuming you don't overheat them....thats only draw back. Overheating happens.....and at $10 a pair, could get pricey.
Later EddieO
EddieO is offline
Old 09-05-2004, 12:40 AM
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
trinity 4499's.
dontfeelcold is offline
Old 09-05-2004, 12:54 AM
Trader Rating: 70 (100%+)
DontFeelCold-
You have obviously NEVER tuned a Reedy,Orion,Peak or Integy(Atlas Motor) stock motor
Guys trinity and putnam brushes do NOT work in these motor's.
Peak Brushes will and by far the favorite is the Reedy 766,767's.
DontfeelCold-It's nice that you have an opinion but PLEASE understand that when your giving advice to someone DONT make them waste their money on a brush that will NOT work in this motor.
If you have TRUE experience or Knowledge with this motor PLEASE share it.If you DONT then Please keep a Opion with NO experience to yourself and not let him waste $3.50-4.00.
TexRacer is offline
Old 09-05-2004, 12:57 AM
Best setup is the following I have found:
Fast Flowing:767's on both sides(766 on the is nice)
Medium to Fast:767 on +,766 on - with a hole drilled in the middle
Tight Smaller tracks:766 on BOTH sides with the - brush having a hole drilled in the face.
DontFeelCold-Im not picking on you and dont take what I say personal.Not meant that way.Trinity's brushes are made of a compound that does NOT work on those motor's.Just please in the future save yourself from giving bad advice.
TexRacer is offline
Old 09-05-2004, 01:03 AM
Default Moster
Tex,
What do you suggest 4 a Monster pro, very open and fast track?
track is actually classed as a fast open 1/10 NITRO track, so on 1/10 elec, you can guess how fast its going to be!!!!
Not the best situation to be, but we cant change that!
Bluey_74 is offline
Old 09-05-2004, 02:49 AM
Default Re: Moster
Originally posted by Bluey_74
Tex,
I use trinity 4503 brushes and putnam green on positive and blue on negative on every track i go to and it works well
Chazz
Chazz is offline
Old 09-05-2004, 11:46 AM
Trinity(Epic) motor's arent as picky as those other motor's that are all actually assembled at the same factory.
Orion&Peak(Top),Reedy(Yokomo),and Integy(Atlas).
The material used on EPIC based stocks comms are simply a different compound.
On a BIG track like that alot of guys favor the
Putnam Greens.Not as much torque as other brushes but good watts and probally the MOST RPM.
Hurricane Golds,Reedy 767's,or a list of trinity's work GOOD but not AS good for big fast flowing tracks.
TRIBO: I do NOT use this product as a comm drop but simply to make the brushes and comm last longer and it does increase effiency.
You CAN NOT use Tribo if you plan on or HAVE used Comm drops on a particular Comm.Use a VERY small amount.Like 1 small drop on the comm itself before a race.
In mod motor's the amount doesnt matter but in stocks it does.
Goodluck Racing guys.
Les
TexRacer is offline
Old 09-05-2004, 01:16 PM
nick51's Avatar
Wut about break in drops?? Is it ok to use tribo if you have used break in drops?
Les
nick51 is offline
