Old 09-05-2004, 06:50 AM   #16
Goot Soldering Iron
you won't be dissapointed
www.bomir.com
Lano is offline   Reply With Quote
Old 09-05-2004, 08:50 AM   #17
picco007's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Like Tres posted there was a thread a while back that had the same information. But all I can tell you is that the Hakko is a great iron. It heats up fast, which is what every racer likes .
Goot is another one to look into.
EA Motorsports
picco007 is offline   Reply With Quote
Old 09-05-2004, 10:04 AM   #18
fatdoggy's Avatar
R/C Tech Charter Subscriber
Hakko irons will just plug straight into a 110v wall socket right? I just broke another cheap 40wt weller so I'm going to buy a decient iron...
fatdoggy is offline   Reply With Quote
Old 09-05-2004, 10:23 AM   #19
Send a message via AIM to A-Ko
At one time I was frustraited with the lack of weller support by my LHS on irons. We do have an excellent HS in my area too. I ended up burning up my heating element and was forced each time to buy a newer model.
Now with Action I just buy the heater element and a few tips per order. I even bought the Iron Temp controller for $32. You can plug in any iron and regulate the output or turn it down to save the tip. It even has an on off switch.
I would not go cheap like radioshack. You get what you pay for and they don't have decent tips.
If you buy an iron make sure you can get part support.......
http://www.action-electronics.com/weller.htm
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 09-05-2004, 03:16 PM   #20
picco007's Avatar
Yep, Hakko irons will plug into the wall. It's the 936 model with the 908 iron or something like that. You will probably need to get the chisel tip for r/c applications. It's a wider than the tip that comes with it in the box. Hope this helps.
EA Motorsports
Old 09-05-2004, 05:45 PM   #21
If you want a good 12V iron there is the new MRT one. It's rated at 40W (max).
ProMaX is offline   Reply With Quote
Old 09-05-2004, 06:06 PM   #22
raving-monkey's Avatar
Send a message via MSN to raving-monkey
looks like the MRT one has replacable tips also..should be good
raving-monkey is offline   Reply With Quote
Old 09-05-2004, 08:47 PM   #23
fatdoggy's Avatar
picco007 - Thanks.
Old 11-17-2010, 10:41 AM   #24
Weller is excellent brand name for soldering iron. Aoyue is less known brand name but - Aoyue manufactures relatively good soldering irons (not as good as Weller ) but much cheaper. In any case I would go with soldering iron which is temperature controlled. That way you can very accurately set temperature of soldering iron.
soldering iron is offline   Reply With Quote
Old 11-17-2010, 10:46 AM   #25
Default Weller 100/140 watt
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
I have this one and at 100/140 watts it makes soldering heavy gauge wire a breeze especially those pesky deans connectors.
Cheers,
Raz
ro.sniper is offline   Reply With Quote
Old 11-17-2010, 10:52 AM   #26
Bishop's Avatar
Some of the cheaper ones are ok (but not many), and yeah the tip design is everything, ignore any iron that comes with like a straight stick in tip held by a screw, they are a waste of money, look for a chunky insert shaped tip held in by a screw over cover, these hold heat better and give more control.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 11-17-2010, 08:55 PM   #27
odpurple's Avatar
Originally Posted by rdub202 View Post
check this beast out i saw an infomercial or commercial or something and it looks pretty pimp cuz it cools right off. i might have to invest in one of these lil buggers. heres the link
Theres's only one problem with those cold heat soldering irons-they don't work
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Best Soldering Iron? snoopyrc Radio and Electronics 30 11-21-2010 10:52 PM
wtb soldering iron pecrichard R/C Items: Wanted to Buy 6 11-17-2010 10:23 AM
Soldering Iron Evilstealth Electric On-Road 7 04-30-2007 12:08 PM
Soldering Iron Flash-R.C. Electric On-Road 10 01-30-2005 05:31 PM
soldering iron??? Matt04 Electric On-Road 12 10-11-2003 11:25 AM
