Old 02-04-2003, 09:07 AM   #361
Damn! that took a long time to read.
This is a great thread! glad I found it.
Thanks JDM for bringing it to the front. I wouldn't have seen it otherwise.
Nanook is offline   Reply With Quote
Old 02-04-2003, 09:43 AM   #362
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Wink No problem
Lots of good reading on this thread.. it' need to have a bump every now and then
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-06-2003, 07:18 AM   #363
what effect would i get in general if i widen the front in relation to the rear wheel base width?
as in the surikarns's 414m2 worlds setup ....the suspension arms were raise to about 4-7mm does this only lower the CG or will it lower the roll center as the CG moves down
fReShJiVe is offline   Reply With Quote
Old 02-06-2003, 10:06 AM   #364
popsracer's Avatar
Default Faster corner speed like pro
Guys;
What are your thoughs on steering angle verses corner speed scrub?
Would you recommend adjusting chassis/suspension for Maximum Front Grip, then using ATV to dial out excess.
My idea being that the less the wheels have to turn in a corner the less speed will be scrubed off due to tire slip. Of course now you may have create a loose condition in the back.
Is this a reasonable assumption or is it just not feasable?
Thanks,
popsracer is offline   Reply With Quote
Old 02-06-2003, 11:59 AM   #365
The effect you will see if nothing else is changed is more front grip & less rear grip. Its not so much that you made the front of the car wider its that you have softened the front suspension.
Sirikarn got two things from raising the pivot point for the lower arms - the arms parallel to the track and moving the RC closer to the CG. He didn't affect the CG because the car was already as low as possible.
dalem is offline   Reply With Quote
Old 02-06-2003, 12:07 PM   #366
Default Re: Faster corner speed like pro
Originally posted by popsracer
What are your thoughs on steering angle verses corner speed scrub?Thanks,
When most people talk about scrubbing corner speed with 'too much' steering they have a car with a push. Their choices are:
1. back out of throttle and wait for more steering
2. crash
Most people try option #1 after tiring of option #2.
The other problem can be incorrect ackerman, where the tires have too much toe in/out but only during a turn.
Generally, the looser the car the faster it is through the turns... until you crash.
Old 02-07-2003, 07:33 PM   #367
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
a LESSER width on any end will MEAN MORE grip on that end .....
and vice versa ....
pops : get ur hands as smooth as posible ... and tune it as loose as posible ... then use radio gear to aid
good for qualifiying
but for race- try to downtune on looseness.... as u will be battling out with other cars on turns ...
imataquito is offline   Reply With Quote
Old 02-08-2003, 01:47 AM   #368
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Default Re: Re: Faster corner speed like pro
2. crash
That may be, generally. But when you get more advanced (as Pops is, or seems to be. . .heh heh) there are more ways to scrub speed through a turn. . .
excessive body roll will scrub speed without inducing a push - this can be solved through droop adjustment or spring changes
excessive steering angle, making the car try to pull itself through the turn (while you could call this a push, it is a self-induced push rather than one in the car - Thirdplace uses this as his common way to turn. It's hell on front tires, but it works well for him) - this is actually using the fronts to slow the car as well as turn it. That's where adjusting a line to NOT shed speed is beneficial. It's something I'm constantly trying to learn from MarkA.
Personally, I don't like a loose car - I like a balanced car. I'm not amazingly fast, I'm just a good steady driver and I find that if I'm in control I'm faster than if I'm out at and just past that ragged edge.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 02-09-2003, 01:29 PM   #369
Hey Jive'
Try the wider front spacers on the front of the Cuda'.. I found that it helps mid corner steering & when going though the twisties
-Dave
Old 02-17-2003, 08:10 AM   #370
Speed Demon's Avatar
mcrisp...
pls check you pm... I've sent you one regarding the book...
thanks,, pls reply..
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 02-17-2003, 08:22 AM   #371
Alvin's Avatar
Mmm activity on the thread. Let's see...
Alvin is offline   Reply With Quote
Old 02-17-2003, 08:24 AM   #372
Alvin's Avatar
For one, the front roll centre will be lowered even further. This will result in more grip at that end, particularly mid to corner exit. Entry might feel a bit slower.
Hard to comment about suri's setup - I have not yet done an accurate analysis (i.e. vernier caliper accurate) of it.
Old 02-17-2003, 08:30 AM   #373
Alvin's Avatar
Note that what I said above is not 100% true in all cases. For example, for MY 414m setup, its roll centre is -4.8mm front, -2.8mm rear. (pro-roll) EDIT: At a ride height of 5mm
In this case, the intersection of the upperlink and lower arm is below the chassis. So when i increase the trackwidth, it actually lowers the roll centre even further.
If suppose you have an intersection point if the upperlink/lowerarm that is above the tire contact patch, then by decreasing the trackwidth, *should* EDIT: lower the roll centre. NB I have not tried my car with such a setting yet.
Old 02-17-2003, 08:35 AM   #374
Alvin's Avatar
Guys;
Hi popsracer! Thanks for your nitro advice in the newbie thread!!!
Now some people determine scrub as the loss of speed as the steering is turned... others determine scrub as the amount of distance the contact patch shifts upon suspension compression.
Now in your case i think it is the first one right? For one I have once set a car that is able to clear all the corners in the track with 50% ATV on my controller. Loose rear end. But when in an actual race situation, my car was actually very very, painfully slow. I believe it is because my car, while able to maintain throttle on my radio, it is not going forward. Kinda like drifting... so in the end I went back to a grip type setup. 100% ATV (actually 88% for me... if I exceed that my servo grinds), i use 100% of the steering in low speed corners, and at the higher speed turns, use less steering.
12th scale pan cars are very good training... funny thing pan cars. The less you steer in high speed corners, the more steering it gets. So i do my training there ;-)
Old 02-17-2003, 09:58 AM   #375
Boomer's Avatar
True! Same thing for 1/10th. Fast and very reactive. Makes better drivers, imho. I know I benefit from it. Small actions beget large reactions.
Driving techniques for faster corner speeds RHCranked Electric On-Road 20 01-15-2006 06:32 PM
carpet corner speed kyracer Electric On-Road 8 01-03-2006 01:20 PM
Corner Speed mutley001 Electric On-Road 9 08-23-2005 01:46 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Corner Speed Chandler Electric On-Road 1 09-21-2004 12:03 PM
