tc3 drivetrain
Old 09-02-2004, 09:19 PM
Default tc3 drivetrain
what are somethings i can do that cost no money, to free up my not so free tc3 drivetrain, any links?
kh15 is offline
Old 09-02-2004, 09:30 PM
Clean and get your bearings spinning as free as possible. Also shim the gears to get it spinning as smooth as possible.
micros_rock is offline
Old 09-02-2004, 09:56 PM
i read an article once that the two bearings that are in the diff caseing like the two bearings that are on the ends of the outdrive well as most of you know if you take one of those bearings off you can push it in to the top part of the caseing and it wont fall out because its a nice tight fit, the article said you should carfully shave down the space where that bearing sits so that when you put the bearing in it and tip the case over it should fall out under its own weight, is that a good idea?
kh15 is offline
Old 09-03-2004, 12:01 AM
go buy the latest edition of Radio Control Touring Car. It tells you everything.
mtc3od is offline
Old 09-03-2004, 07:10 AM
Brandon Melton's Avatar
kh15- That's correct but don't dremel too much or it gets sloppy and the diff will move around in the case. I have dremel bit about the same size as the bearing curvature, just a light touch which appears to just "scuff" the case is usually all it takes. However, the most important thing is using shims correctly to get proper backlash on the ring-pinion gears. Getting proper mesh would help more so than proper treatment of bearing with bad backlash, so get that right first. The way they tell you to shim in the manual isn't "always" the best for each car, so play with that for a bit.
Brandon Melton is offline
Old 09-05-2004, 09:26 AM
Registered User
That's interesting some of you suggest shimming, I got the best amount of freespin out of the drivetrain by removing all the shims in the car. The spur can walk a little in it's hub but it spins much more free than it did when it was properly shimmed. It tends to stay loose from the diff rather than being tight and adding drag.
I'd try both and see what happens.
mtc3od is right, that mag has clear pictures and everything in case your confused at all.
If your willing to keep up on the maintenance, I found removing all the bearing seals off all the bearings and running them dry helped a little too. But it requires cleaning more frequently, I have to clean mine every week.
Desolas is offline
Old 09-05-2004, 02:21 PM
Charlie O's Avatar
Default Ditto
I got the same results from not shimming, much more free, kind of floating.
Charlie O is offline
Old 09-05-2004, 03:37 PM
onnetz's Avatar
I tried it without the shims and it was more free, but it also resulted in more torque steer. I ended up putting the shims back in.
onnetz is offline
Old 09-05-2004, 08:11 PM
whats tourque steer?
kh15 is offline
Old 09-05-2004, 08:32 PM
Blakesrc's Avatar
Trader Rating: 26 (100%+)
Kh15,
Torque Steer is when you punch the throttle and the car tends to turn off in one direction on its own.
Brandon Melton,
What do you mean by "backlash"?
Thanks,
Blake
Blakesrc is offline
Old 09-05-2004, 09:38 PM
oh
kh15 is offline
