Old 09-02-2004, 12:58 PM   #1
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Default battery building guide.
right, i just got some new 3600s and i want to build them right this time (Was a disastor with my 3300s, dont ask! )
so i was wondering if there were good guides out there on how tob uild batteries.
i came accross 1 but it seemed a bit rubbish and the pics wer ein black and white
thanks
Matt
raving-monkey is offline   Reply With Quote
Old 09-02-2004, 01:11 PM   #2
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
A deans battery jig is a must!!!!! Makes everthing fall into place nicely
ALBERTO is offline   Reply With Quote
Old 09-02-2004, 01:13 PM   #3
i got an orion one...seems to do its job ok..may look into getting a deans one if its a must have
but are there any good guides on the internet?
Old 09-02-2004, 01:22 PM   #4
Chill Will's Avatar
Buy a Deans.... You will kick yourself for not buying one long time ago. You might have to squeeze the 3600s in it....... Use a light grit sand paper on both ends of the battery first. Make sure you have a good Hot Iron. Don't put any soldier between the battery and the bars. Let the soldier melt over the bars on each side................. Or next time order some Promatch batteries and they will do it for you.
Chill Will is offline   Reply With Quote
Old 09-02-2004, 01:58 PM   #5
snopro31's Avatar
Trader Rating: 36 (100%+)
the orion one works ok if you put rubber bands around it to hold the cells inplace better. as long as you have a good soldering iron with a good sized tip. you can solder the cells with out putting to much heat into them. just take your time and it should work out ok.
snopro31 is offline   Reply With Quote
Old 09-02-2004, 01:59 PM   #6
ALBERTO's Avatar
Originally posted by Chill Will
Don't put any soldier between the battery and the bars. Let the soldier melt over the bars on each side..................
y not ????
Old 09-02-2004, 02:34 PM   #7
thanks again guys..i might have to look into a deans jig.
i usually use a 12v iron for all my batteires, motors..and a gas one for general soldering.
thanks again
Matt
Old 09-02-2004, 02:42 PM   #8
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
Originally posted by ALBERTO
y not ????
Because direct contact between the bar and the cell is better than alot of solder between them. Solder is a good mechanical joint but you don't need alot hindering the electrical connection.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 09-02-2004, 02:52 PM   #9
what about solder....
is it best to use just plain solder and some flux..or rosin cored solder (somet like that )
want to get these packs right
Old 09-02-2004, 03:17 PM   #10
j240z's Avatar
Default Dean's!!!
I've always had great results with a Dean's jig and Dean's solder! Just watch out for those fumes....
j240z is offline   Reply With Quote
Old 09-02-2004, 03:26 PM   #11
soldering awlays gets down in the cellar..and we have an extractor fan in there (dont ask why, it was there when we moved in )
the cellar is mine....allllll mine got a work space etc to do all the work on my cars, etc etc
Old 09-02-2004, 03:27 PM   #12
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Whats wrong with solder fumes? Breathe deep son....it puts hair on your (diff) balls.
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 09-02-2004, 03:28 PM   #13
hahahahahahaha....what about petrol....that smells nice to
Old 09-02-2004, 03:46 PM   #14
hierog's Avatar
Default --
make sure you sand the ends of the batteries very well! i used a dremel with a sanding tool on it. makes a ton of difference making sure the battery bars stick!
hierog is offline   Reply With Quote
Old 09-02-2004, 03:49 PM   #15
sosidge's Avatar
Default Re: --
You shouldn't need to do this. Solder flux will do a much better job of cleaning the contacts than sanding will. Use a seperate flux if your having problems, also make sure your iron is up to the job.
Battery building Dragonfish Rookie Zone 6 07-26-2008 10:53 AM
battery building buffalobill989 Electric On-Road 9 04-25-2007 08:30 PM
Battery Building Nismospeed Electric On-Road 2 12-29-2001 08:03 PM
Battery Building Nismospeed Racing Forum 1 12-29-2001 06:30 PM
