Like Tree235Likes
Team Associated TC4
Old 07-20-2018, 04:48 PM
  #15781
Conrad's Avatar
Originally Posted by fircrest View Post
Nope! This storm was the last draw for me, I'm ordering a snow thrower. In my 20s I didn't mind shoveling, but now in my 30s I despise it, I'm sore all day after shoveling my huge driveway hahaha
JC3 - I've done the front DCV conversion and I absolutely love it. Turns are smother and I can finally run the steering lock to lock without massive chattering with the front spool. I highly recommend it - that is if you're committed to the TC4 chassis. For mine I went with the tc7 steering block, not the shapeways one.
Expected cost would be...
ASC 31632 DCV kit: $38.99
ASC 31679 Steering Block: $6.99
5x10x4 bearings (x2): most hobby shops have them for about $1 each
5x10x3 bearings (x2): same as above
ASC 31370 Axle Crush Tubes: $3.99
ASC 31112 Dowel Pins: $3.49
ASC 31670 Wheel Hex: $14.49
This is for everything, with all the "proper" parts for a smooth/direct install. Again, it isn't cheap, but it sure is nice in the end!
How deep in to the front diff outdrives to the DCV pins sit? I had the Losi kit years ago and they were right on the edge of falling out just sitting on the bench.
Conrad is offline
Old 07-23-2018, 04:31 AM
  #15782
Does anyone know if the b44 rear shock tower mount will bolt up to the tc4 differential housing? I'm looking for a mount for a custom carbon shock tower and want something taller than the TC4 FT mount. Thanks
zmlnr8 is offline
Old 07-23-2018, 05:39 AM
  #15783
MD
MD's Avatar
Trader Rating: 126 (100%+)
You may want to email Team Associated with the question.
MD is offline
Old 07-23-2018, 07:54 AM
  #15784
Good call, will do. Thanks!
zmlnr8 is offline
Old 08-04-2018, 08:59 AM
  #15785
Anyone have any tips or suggestions on how to remove the front outer hinge pin? I've got to switch out a caster block and I'm having a hard time getting that pin out.
DoubleRR24 is offline
Old 08-04-2018, 01:31 PM
  #15786
RAL
RAL's Avatar
Trader Rating: 62 (100%+)
Try to find a punch thats just a tad smaller then the pin in diameter at the hardware store or local gun shop. Take the arm and rest it on its edge on the workbench and tap it out with a hammer.
RAL is offline
Old 08-09-2018, 01:58 PM
  #15787
I want to change out the steel turnbuckles for something lighter but not sure what size or thread type the stock one is. Would the metric ones like this Tamiya work? Tamiya, 3X32mm Alum. Turnbuckle Shaft ,(54249)
userst is offline
Old 08-09-2018, 02:08 PM
  #15788
SteveM's Avatar
Trader Rating: 150 (100%+)
Best to get a set of Lunsford turnbuckles, Lunsford 2037 Titanium Turnbuckle Kit. (#4037 gets you the turnbuckles and all hinge pins)
THEBIGBULL likes this.
SteveM is offline
Old 08-10-2018, 01:12 AM
  #15789
RotorTruck's Avatar
I use a thumbtack thru the little hole. Tap it in. Ive found if they need to come out using this method, they're usually toast.
RotorTruck is offline
Old 08-10-2018, 09:11 AM
  #15790
QueadlunnRau's Avatar
+1 on the thumbtack punch
Though the hingepin might just be slightly bent, in that case I just take my time to bend it straight till it can roll pretty freely cause I'm to cheap and impatient to wait for parts sometimes.
QueadlunnRau is offline
Old 10-09-2018, 10:00 AM
  #15791
CraigH's Avatar
Time for it go
http://rover.ebay.com/rover/1/711-53...g&toolid=11111
CraigH is offline
Old 10-09-2018, 10:08 AM
  #15792
JC3
JC3's Avatar
Originally Posted by CraigH View Post
Go for what? The link doesn't point to anything!
JC3 is offline
Old 10-09-2018, 10:21 AM
  #15793
CraigH's Avatar
Sorry the auction isnt live yet.. my bad Its a Kaizen TC4 Will post when it goes live
CraigH is offline
Old 10-09-2018, 10:48 AM
  #15794
JC3
JC3's Avatar
Okay, so you are selling.
JC3 is offline
Old 10-09-2018, 07:06 PM
  #15795
CraigH's Avatar
Active now-For Sale
Kaizen TC4
Billy Kelly likes this.
CraigH is offline
