Like Tree238Likes
Team Associated TC4
Old 03-26-2018, 06:39 PM
  #15661
JC3
JC3's Avatar
Originally Posted by DoubleRR24 View Post
I run at Ho-b RC Park at Northgate Mall.
This is the setup I was running for practice on Sunday.
It's very cool to see these setup sheets. Looking forward to seeing more. Thanks.
FWIW, taking the correct lines and carrying speed through the corners is, IMO, easily worth a second or more. If you're hitting the wall, you're losing time for sure. Not only since your way off line but also because of the fact that you're slowing the car way down from contact and also losing valuable time getting it back together to get back on line. As of now, my biggest problem isn't car setup, it's inconsistency. The leader (Serpent chassis) in my Main race on Sunday was doing 11.0's. His average time was - ready for this - 11.05! His consistency rating, good grief, was 97%!! Mine, by contrast was 79%. It matters.
Here is his lap chart!
Here's mine. Ugh. The spikes are mainly where I got mixed up in traffic, got off line, or got bashed by somebody. lol
JC3 is offline
Old 03-27-2018, 05:19 AM
  #15662
Falconz's Avatar
Hey, me too. If you want we can get together one day and swap cars and go over setup stuff.
DarthBacon101 likes this.
Falconz is offline
Old 03-27-2018, 05:32 AM
  #15663
Falconz's Avatar
See if this works. This is the setup I ran last race.
File Type: pdf
JC3 likes this.
Falconz is offline
Old 03-27-2018, 05:46 AM
  #15664
mleemor60's Avatar
Trader Rating: 28 (100%+)
You guy's in Durham need to come over and try Kannapolis Raceway Park. Next event for us is April 14th. We always run VTA.
mleemor60 is offline
Old 03-27-2018, 05:57 AM
  #15665
Falconz's Avatar
I've been watching and really want to, but I usually have to work the Saturdays you guys are racing. Sundays are always open for me. I'll make it there one day.
Falconz is offline
Old 03-27-2018, 06:22 AM
  #15666
mleemor60's Avatar
We chose Saturdays so it wouldn't affect the Durham group and would allow us to come up there once in a while. And we will. In fact I almost stopped there on Sunday since we were passing by from a race trip in Maryland. Didn't though since we were trying to get home to watch Martinsville. We didn't know it had been postponed. Oh well, maybe next time.
Old 03-28-2018, 06:56 AM
  #15667
Just so I'm not buying the wrong parts. The right length shocks for the TC4 are 60mm, right?
Nerobro is offline
Old 03-28-2018, 09:27 AM
  #15668
Broadwater's Avatar
I'm using 55mm
Broadwater is offline
Old 03-28-2018, 10:24 AM
  #15669
JC3
JC3's Avatar
I'm using the 60's with the Associated springs. SteveM used the 55's with different shaft ends to get the length/adjustment that he liked. You'll need some additional screws/nuts to accommodate the slightly different YR hardware. See my and SteveM's earlier posts for the details.
After several long practices and one race day, no leaks or problems at all. I like what SteveM recommends, some green Slime and different o-rings. I'll be using the stock YR o-rings but adding some Slime with the next oil change. Let us know how yours work out. Oh, RcMart will require a signature for delivery, it sucks but if you know you can plan for it.
JC3 is offline
Old 03-28-2018, 10:35 AM
  #15670
I did a bad thing, and didn't tell you the whole story.
I was looking at picking up 3-racing shocks for my TC4. I bought some 50mm ones with that intent, but they're a bit short. I ~love~ the shocks though, hard anno barrels, TiN coated shafts. Foam backed rubber bladders. They assembled fast, and without trying they all have the same rebound without having to rebuild any of them.
.... I'm sold on them. :-) and 50mm I think is the right size for my minis. And my M07 could use a set.
I use green slime on the seals. I bought a whole noleen SF3 jar...
Nerobro is offline
Old 03-28-2018, 10:43 AM
  #15671
JC3
JC3's Avatar
FWIW, I'm impressed with the YR's too. Quality is nice and the adjustment ring has a notch built in. Came with extra o-rings, numerous parts, foam backed bladders, some clever tapered hole pistons, oil, and extra springs. Quite a lot for the money. I had one hell of a time getting mine built with regard to rebound. Took me numerous tries but it was the first time I'd ever done it. Ended up with around 25% in two of them and around 20% in the other two. I just couldn't stand to mess with them any more to get them perfect. Next time. Put the 3R shocks up for sale, somebody will want them.
JC3 is offline
Old 03-28-2018, 10:58 AM
  #15672
I believe I own some yeahracing shocks. They didn't come with bladders... They weren't as nice as the TRF shocks I've built, but they weren't far off.
JC3 likes this.
Nerobro is offline
Old 03-28-2018, 01:46 PM
  #15673
I have some YR shocks but replaced them with the TRF shocks, the YR shocks work well in my TT02
PJRacer is offline
Old 03-28-2018, 02:34 PM
  #15674
gigaplex's Avatar
You'll probably need the 54790 shock towers for the M07 to use the 50mm shocks, or use the longer ball end on the shock.
Nerobro likes this.
gigaplex is offline
Old 03-28-2018, 03:39 PM
  #15675
Teamhotrods's Avatar
Running the TC7.1ís with cut down towers from reflex racing
Attached Thumbnails Team Associated TC4-6a13467b-ba72-40d8-9ce5-8c2522895148.jpeg
Teamhotrods is offline
