Like Tree236Likes
Team Associated TC4
Old 01-22-2018, 10:40 AM
  #15436
mleemor60's Avatar
Trader Rating: 26 (100%+)
Steve. New VTA rules?
mleemor60 is offline
Old 01-23-2018, 01:30 PM
  #15437
SteveM's Avatar
Trader Rating: 150 (100%+)
Yes, the US and Canadian VTA rules now require a 25.5 motor down from the 21.5.
SteveM is offline
Old 01-23-2018, 01:40 PM
  #15438
SteveM's Avatar
Yeah Racing 55mm aluminum shock update #3
As I mentioned earlier, I replaced the stock plastic shocks on my TC4 Club Racer with a set from Yeah Racing. They build well but I found them very stiff and felt they should be better. I was still able to take TQ and win the Amain in the last two races but the stiffness was bothering me.
Today I took them apart again and noticed that the clear O-rings supplied were too tight on the shock shaft. I replaced them all with some from Tamiya and along with some AE Green Slime rebuilt all 4 shocks. They are so much better now it's like night and day. Thought folks might want to know.
RAL, DMD and InfamousRacerX like this.
SteveM is offline
Old 01-23-2018, 02:28 PM
  #15439
Teamhotrods's Avatar
US VTA has always been 25.5. I think the Canadians are following the standard 25.5 now. They always try to get away with something... :-)
gigaplex likes this.
Teamhotrods is offline
Old 01-23-2018, 03:15 PM
  #15440
SteveM's Avatar
Only if we can....eh.
Teamhotrods likes this.
SteveM is offline
Old 01-24-2018, 10:11 AM
  #15441
beyondthepack's Avatar
Default tub or carbon?
just curious if anyone has found the tub chassis to be more effective on Black carpet. My Diggity was a monster on grey carpet.
I want to build a VTA from the Tub, but was looking for some feedback on black carpet, any help is welcome.
beyondthepack is offline
Old 01-25-2018, 06:03 AM
  #15442
SteveM's Avatar
Originally Posted by gigaplex View Post
Making progress. Not sure why they've changed the rear body post locations with this shock tower. Roughly half way between the original TC4 holes and TC5 holes which is too close to re-drill on my current body.
You can always use the stock rear shock tower and your body post holes would line up again.
SteveM is offline
Old 01-25-2018, 06:51 AM
  #15443
gigaplex's Avatar
That's the plan until I get some custom shock towers made up to allow me to use short shocks from my Tamiya Mini cars. I'll see if I can get it to match the TC5 post locations so I can share bodies between my cars.
gigaplex is offline
Old 01-25-2018, 10:06 AM
  #15444
fircrest's Avatar
I might be interested in taking that shock tower off your hands if you have no need for it
fircrest is offline
Old 01-28-2018, 01:55 PM
  #15445
fircrest's Avatar
Now that Iím completely satisfied with the KFR conversion build Iíve decided to start an ďultimate tub racerĒ build using a bunch of leftovers as well as some new parts. Btw the tub chassis is on sale for $10 on the Associated website. Last night I completed all the necessary dremelling and started piecing things together. Iím debating wether or not I want to get some tc7.1 dcv shafts like I did with my Kaizen build or keep the pretty blue shafts. Only arm mount I need to finish matching them all is the blue square mount.
fircrest is offline
Old 01-28-2018, 02:25 PM
  #15446
I like what you did there with the battery. What components did you use to do that?
DoubleRR24 is offline
Old 01-28-2018, 02:34 PM
  #15447
fircrest's Avatar
Thanks dude. Itís the TC7.1 ĎFactory team hook & loop battery strap kití (asc31645). I just needed to trim the outer side of the ďLĒ brackets to fit the lipo in then drill the tapered screw holes in the chassis. Fits like a glove.
fircrest is offline
Old 01-28-2018, 04:23 PM
  #15448
I'll give that a shot. Any chance you could show some up close pictures? Did the screws come with the kit? If not, what screws did you use to secure it to the chassis?
Old 01-28-2018, 04:54 PM
  #15449
I put 55 on my sprint 60ís on my tc3 and tc4 and for me the 60ís response and handling was spot on.
Today was my first center driveshaft kaboom.
It was probably my fault. Cause I was having a deans connection problem
And I blipped the throttle to make sure it wasnít going to shut off.
Rear drive cup split in half and shaft looks like a spaghetti noodle
Car is so old and something bound to break sooner or later
grabbem88 is offline
Old 01-28-2018, 05:59 PM
  #15450
fircrest's Avatar
Screws were not included, I just found some m3 flatheads I had sitting around. There are supposed to be two per side but Iíve had success with only using one. Here are some more detailed pics.
fircrest is offline
