Team Associated TC4
Mark
Making progress. Not sure why they've changed the rear body post locations with this shock tower. Roughly half way between the original TC4 holes and TC5 holes which is too close to re-drill on my current body.
True, but it's a very poorly designed one. It will crack right in the middle of the 'V' on impacts and break. Adding a servo saver to the server seems to eliminate the steering rack breakage almost completely. I broke a couple when I first started racing my TC4 in 2014, haven't broken one since. And now it's a loaner which is used frequently by beginners who beat the snot out of the car.
Just trying to help the guy out.
Mark
Mark
Mark
Mark
thanks
The TC4 steering rack has it's own built-in servo saver and I have never felt the need to use a second one.
Here's some answers from a TC4 USVTA racer.
1. Upgrade to some coil over shocks. The VCS2 or VCS3 are a good choice from Associated. This will make it easier on you to get the setup right.
Also, add a servo saver to the servo. Otherwise you'll break steering racks. Right, ITZNicholas72?
2. Your class rules will determine this. Some clubs run 25.5 motors, others run 21.5 motors in VTA. The USVTA rules are Novak 25.5 motors only. So check with your club/track before you buy a motor.
3. The usual list of suspects: C-hubs (caster blocks) are prone to breakage if you hit a lot of stuff.
If you use the stock front spool, you're likely to break the plastic outdrives in impacts (I think...I don't run a spool so I don't know if it's steel or composite).
I also recommend the steel TC3 axles for the front, or the TC4 Factory Team aluminum front axles. Much more durable than the stock composite axles.
4. The stock blue springs should get you close, find some Associated silvers for the rear. This is popular combo.
5. The VTA rules specify the wheels and tires to use.
U.S. Vintage Trans-Am R/C Racing Series
6. The kit shock weight is 40wt. That's a great starting point.
The TC4 is a good, solid starter car for USVTA. I loan mine out to beginners and people wanting to try out on-road. So far, the only thing they've managed to break is a bunch of bodies and a c-hub or two.
Good luck!
Good luck!
thanks to you guys on servo saver info! The stock so called servo saver is a joke! I just ordered 2 for 2 cars!
EDIT: you'll need to grind the chassis support webs away in front of the servo to make clearance for the servo saver. A couple of minutes with a dremel is all it takes.
Mark
I used the TC6 shocks on my Kaizen conversion and my rear arms sit level with the chassis.
I ran my TC4 today with the YR shocks in the VTA class for the first time. I built the shocks with 40wt oil and used the super soft springs in the rear and soft springs up front. The car's suspension felt really stiff but I decided to give it a try anyway.
This is my first experience with the Protoform VTA tires and they felt awful. Worse even that the old HPI stuff and I had no traction anywhere. I tried to get as many warm-up laps as I could before each qualifier in the hopes of scrubbing in the tires. Traction got a bit better as the day progressed and the tires improved with track time.
I ran a Hobbywing 25.5 motor and so did Guy. Everyone else ran 21.5 motors with the exception of Nick who ran a 27 turn brushed motor setup. I managed to take the TQ and won the A-main by two laps. Not too bad considering. My results are in the attached picture.
I was TQ and won the A-main again today and my results are below. I am the only racer running a 25.5 in keeping with the new VTA rules. All others ran a 21.5 while my club transitions to the new rules.
When I had my Tc4 i never broke a steering linkage but that was due to the Extra hard bumper , I think it was made by Parma . Im not sure if you can still get themu
