Like Tree232Likes
Team Associated TC4
Old 01-25-2017, 06:36 AM
  #15031
DarthRacer's Avatar
Originally Posted by jiml View Post
Dumb question is the club racer still available? I thought it was discontinued when the new RTR was released.
It is available.
http://www3.towerhobbies.com/cgi-bin...&I=LXCFLH&P=ML
DarthRacer is offline
Old 01-25-2017, 10:42 AM
  #15032
beyondthepack's Avatar
Default DC4 LE
Hey guys I picked up a DC4 LE for my VTA, and looking for a starter set-up, all I can find is the traditional tub chassis. Any page links that can help would be great.
beyondthepack is offline
Old 01-25-2017, 02:22 PM
  #15033
That looks awesome....
djgrom is offline
Old 01-25-2017, 03:52 PM
  #15034
I'm also busy building one of these and I'm almost done so a good starting setup will be helpful. Ill be running 21.5 with foams on medium grip carpet.
PJRacer is offline
Old 01-25-2017, 04:52 PM
  #15035
Smile
Check Diggity web site, I believe their is a sample set up sheet, also check building manual for initial build set up.
THEBIGBULL is offline
Old 01-28-2017, 06:21 AM
  #15036
Originally Posted by PJRacer View Post
You can get one of these if you are in a hurry
https://www.shapeways.com/product/ZK...9/tc4-ft-mount
Donít buy in Alumide as it has too much flex and the screws wont last. Aluminum is expensive though @ $60.
Below is one I received yesterday. Iím still designing my own as I donít like the screw accessibility on this one and people have been complaining about it since the FTTC4 was launched
Has anyone tried this mount on the Diggity Kit yet?
Old 01-29-2017, 07:20 AM
  #15037
There were only 50 diggity kits so I am guessing no.
djgrom is offline
Old 01-29-2017, 10:36 AM
  #15038
that post had a picture of the motor mount mounted to my new diggity chassis. It was printed in Alumide (Metalic plastic).
The diggity chassis uses the original FTTC4 motor mount.
PJRacer is offline
Old 01-29-2017, 07:12 PM
  #15039
NutDriver's Avatar
Trader Rating: 20 (100%+)
No, it doesn't. I have two of the fifty Diggity Designs DC4LE conversions and neither of them do.
NutDriver is online now
Old 01-29-2017, 09:40 PM
  #15040
Not sure about the original 50, but as can be seen on the pictures I posted, the new DC4 Narrow chassis takes the motor mount for the FTTC4 (Not the tub motor mount)
Also I asked on the diggity forum and I got confirmation there that they were the same before I bought it.
PJRacer is offline
Old 01-30-2017, 12:00 PM
  #15041
Good to know, might be picking one up for a spare.
What did people find were the advantages, or disadvantages of running the rear camber link on the chassis brace cut out as opposed to the shock tower.
Old 01-30-2017, 06:36 PM
  #15042
RotorTruck's Avatar
https://www.teamassociated.com/pdf/c...yrace_2006.pdf
I run this Brent Thielke setup on my Diggity in USGT, w/17.5 (local class). But without any swaybars. It works quite well, but have to be careful when exiting a tight corner on throttle, the shaft drive really spins up the tires and it can oversteer. A more gradual throttle application would help me.
One thing I noticed with the Diggity vs. plastic tub, the Diggity has *gobs* more steering.
RotorTruck is offline
Old 02-03-2017, 08:35 AM
  #15043
I pulled a similar set up off the Diggty Design page, with the exception of minor changes. always good to have more set-ups.
Old 02-03-2017, 01:46 PM
  #15044
Tech Legend
Marcos.J's Avatar
Trader Rating: 199 (100%+)
has anyone tried the apex gear diff in the tc4? looks very close
Marcos.J is offline
Old 02-04-2017, 12:43 PM
  #15045
What shocks are people using instead of the standard shocks with the VCS2 upgrade.
The VCS2 upgrade was okay back in the day but shock design has changed a lot. Im looking for replacement shocks that will fit my old springs. How is the TRF shocks?
http://www.rcmart.com/tamiya-42102-5...d-p-23733.html
Anyone tried these?
PJRacer is offline
