Leaky TC3 Factory Team shocks >
Old 09-01-2004, 08:19 AM
Default Leaky TC3 Factory Team shocks
I was assembling some TC3 factory team shocks and they call for a rubber O-Ring in the instructions. When I assemble them with the O-Ring it squeezes out the side and they leak?
Can I sub some thread tape or something and ditch the O-Ring?
Jeremy
jlou671 is offline
Old 09-01-2004, 09:23 AM
Chill Will's Avatar
Sub with Losi shocks. Mine handles much better.
The shocks will leak a little till the O ring seats if they are built correct.
Chill Will is offline
Old 09-01-2004, 12:20 PM
I should have been more specific.. The O-Ring at that goes around the top of the shock body underneath the shock cap. not the two o-rings in the bottom of the shock. Those are fine.
jlou671 is offline
Old 09-01-2004, 12:27 PM
StephenSobottka's Avatar
Make sure the o-ring did not roll on, it will twist and then cause it to squish out. Make sure that the shock cap does not have any flashing on it either.
StephenSobottka is offline
Old 09-01-2004, 12:55 PM
J-P
J-P's Avatar
i use yokomo shock caps and bladders, much better and they have instructions on how to fit to tc3
J-P
J-P is offline
Old 09-01-2004, 02:24 PM
Now that I think of it.. I did roll the O-ring on. I will check it out when I get home and post my results.
jlou671 is offline
