Old 05-23-2005, 07:30 PM   #1276
JohnB's Avatar
R/C Tech Charter Subscriber
He's probably asleep already. Had to go do real work today
JohnB is offline   Reply With Quote
Old 05-25-2005, 04:39 PM   #1277
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Hey Guys, under the damper plate, should I put any grease or should I leave it dry?
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 05-25-2005, 05:10 PM   #1278
JohnB's Avatar
Yes, you want to lube it. Just a little on top and bottome disk.
100wt. shock oil is probably what SG1 will tell you to use. I like Losi Hydra Fluid medium or heavy. Also Trinity white and red grease for some real heavy dampening.
take care
john
Old 05-25-2005, 06:47 PM   #1279
Moderator
For the 3 shock setup....i noticed the holes for the shocks on the side are too small for the regular 4/40 ballstuds to drop in....should we tap the carbon fiber? or drill and then lock it down with the 4-40 nuts?
SMC Racing
Old 05-25-2005, 07:11 PM   #1280
Trader Rating: 14 (100%+)
Stephen:
Hi,
I just tapped mine. worked great. hope to see you at Vegas if not sooner. we;re wiating on the new ferry from Muskegon to Milwalkee (sp??) to start up again. maybe we will hop on and come over and race.
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 05-25-2005, 07:20 PM   #1281
Moderator
I just tapped mine too, easy enough. That would be cool! Let us know in advance if you plan on coming over so I can get off of work!
SMC Racing
Old 05-25-2005, 07:25 PM   #1282
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Stephan,
With the dampner disks, 100 wt. oil works well. The side shocks, tap the holes on the top plate 4-40 and the inner most holes of the chassis brace. Then shim the ball studs on the chassis brace up 2 washers. 40 or 50 wt. oil and use RPM ball cups so the piston doesn't bottom out. Remeber to take the tweek screws out with the shocks. Set the center shock about 3/32" too long when you snap it on so the piston doesn't bottom out if the pod rolls back.The chassis should be at .5mm rake, rear higher. Then the top of the pod should be level. That will have the "droop" set correctly. The front end, .022" springs, 10 deg. uprights and 1 deg. camber. Mount the servo flat to chassis and ball studs on backside of servo saver. Make turnbuckles parallel with chassis and straight across. Umm...Purple fronts and magents rears for stock will work on most tracks and a .072 to .075 t-bar on club tracks. High bite tracks, .080" t-bar works better. Try the batteries in the middle to start.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 05-25-2005, 07:42 PM   #1283
Moderator
Wayne- I guessed on the shocks and we mounted them slightly different..heh I used 30 wt oil.....is this too light for club racing? I have no idea how to disassemble the shocks now lol, they arent normal for me! haha I was going to use a gold side spring and silver middle?
SMC Racing
Old 05-25-2005, 08:24 PM   #1284
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Stephen, Green or Silver middle probably.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-26-2005, 06:13 PM   #1285
sg1
sg1's Avatar
You may want to up it to 40 wt. atleast... If the track has no or little traction you'll be ok, but when bite comes up it's too light. The green center spring works well on average bite conditions, if you need more steering go to the silver.
Old 05-26-2005, 06:22 PM   #1286
protc3's Avatar
hey guys,
i came up with the replacement parts list but my dumb a$$ keeps forgeting to bring it home to post them for you.i will try to remember tommorow but if i dont,you can always call for pricing.now its time to get the 1/12th ready for domination this weekend.seems like the BMI 1/12th is cleaning house everywhere i look.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-26-2005, 06:34 PM   #1287
sg1
sg1's Avatar
Jason,
Did you find time to get my project done ????
Old 05-27-2005, 11:05 PM   #1288
Tim Stamper's Avatar
Originally Posted by TimXLB
Stephen:
Hi,
Tim,
Gimme a call if you get a chance this weekend. Got a couple of TC questions for ya. Gonna be running the 1/12th scale at 'ScrewZ tomorrow in practice to blow off some steam. I just wish that people ran 1/12th here year round. Would be more fun that way.
Tim
This space for rent
Tim Stamper is offline   Reply With Quote
Old 05-30-2005, 10:39 AM   #1289
sg1
sg1's Avatar
Tim,
How did the 1/12 go?
Anybody else run 1/12 this weekend??
Old 05-30-2005, 01:08 PM   #1290
Moderator
Wayne- The niftech axle and diff is together, and the shocks are mounted. I am waiting for a front end kit to come in and t-bar brace. Thats pretty much about it.
SMC Racing
B44 conversion to T44 Craps Electric Off-Road 31 04-22-2011 06:06 PM
Electric Conversion REVO, who makes the best conversion? rclab1 Monster Trucks 3 11-25-2007 12:27 PM
CONVERSION 32819toon Nitro On-Road 6 05-02-2006 01:07 AM
WTB a LCG conversion kit MoFO R/C Items: Wanted to Buy 0 09-24-2005 07:40 PM
