Old 04-29-2005, 12:11 PM   #1186
Send a message via AIM to NuckingFutz Send a message via Yahoo to NuckingFutz
i was thinking of putting my reciever up front but figured a 25.00 servo would be cheaper to replace instead of my reciever but i like the layout of yours as well i might have to try that..im still new to 1/12th but progressing everyday
NuckingFutz is offline   Reply With Quote
Old 04-29-2005, 12:11 PM   #1187
is that suppesed to be pink or red either which way looks good
Old 04-29-2005, 01:40 PM   #1188
SA_Racer's Avatar
Default Thanks Jason
Originally posted by protc3
SA Racer,
for your set up,try this:
pink rear tires
purple fronts
.022 front springs
olive center spring on shock and 30 wt. oil in the shock
.075 T plate
1000 wt. oil in dampening washers(1/8th scale diff oil)
5mm ride height in rear of chassis
4.5mm ride height in front of chassis
5mm pod ride height and make sure the pod is level with you ride height gauge.set the shock collar to just touch the spring on your shock at full extension and set your pod level by adjusting the ball cups on the shock.this is very critical.do not crank down on spring or you will lose your droop setting.
10 degree castor in front(5 deg,or 0 deg. if you find it too aggresive)
1 degree camber up front
servo on angled mount
speed 8 body(parma)
let me know how it goes.i run this set up on asphalt in 19 turn.
jason
Thanks Jason, Ill give this a shot.
Wayne, I got a a new servo today (Just in case), I verified my droop and I definately have enough of it. ill try the tips you guys suggested and let you know the outcome after sunday
Till later
PJ
SA_Racer is offline   Reply With Quote
Old 04-30-2005, 03:25 PM   #1189
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
JohnB...
The goods have been ordered!!! Now everyone will want to know what goods...lol...
Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 04-30-2005, 04:42 PM   #1190
dakrat's Avatar
putting the rx on the front will look really stupid with all the wires hook up. i thought about that before.
dakrat is offline   Reply With Quote
Old 04-30-2005, 05:09 PM   #1191
N4S
N4S's Avatar
Hey jason is that the set up you were running when i handed you your ar$e last weekend ?
N4S is offline   Reply With Quote
Old 04-30-2005, 05:10 PM   #1192
N4S
N4S's Avatar
Sorry guys its like a sickness .......... I just can't stop.
Old 04-30-2005, 06:40 PM   #1193
protc3's Avatar
coming from a guy who was 3 seconds off pace per lap.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-30-2005, 07:33 PM   #1194
N4S
N4S's Avatar
Lay off the traction compound !!!!!!!!! Time seems to stand still when you sniff the can. Kinda like your car when i lap you........ Just be ready if the rain passes tomorrow to whip out the ole' towel
Old 04-30-2005, 10:19 PM   #1195
protc3's Avatar
puff puff give dude.i need to try some of this stuff your smoking. its on now beotch
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-01-2005, 01:58 PM   #1196
fatdoggy's Avatar
R/C Tech Charter Subscriber
Jason - Could you give us a listing of how much each piece in the conversion would cost? Chassis brace, lower pod plate, upper pod plate. I'd like to order some spares.
Thanks.
fatdoggy is offline   Reply With Quote
Old 05-01-2005, 05:12 PM   #1197
N4S
N4S's Avatar
Give him some time guys....... He is still licking his wounds from today. How ya like me now beotch
Old 05-01-2005, 07:52 PM   #1198
theisgroup's Avatar
the bmil4 was the fastest on the track. too bad I did not have the new 3700 or 3800 to make runtime. Seams i am not good enough to make 8 min with a 10x1. so i could only put the car in 3rd. got beat by 3700gps.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 05-01-2005, 08:17 PM   #1199
JJ187RC's Avatar
You are right Yang, you are not good enough!!!!!! lol Just kidding.
JJ187RC is offline   Reply With Quote
Old 05-01-2005, 08:27 PM   #1200
theisgroup's Avatar
JJ,
you should have run today. was a lot of fun. lap traffic was not too bad today. he stay out of most people's way. He actually got in with Tim and I actually put Tim a lap down until I dumped in the first qual. I laped him 6 min in on a 40 8:06 pace. I was hoping that you would bring your high cap batts so that I could use them
Ran the BMIL4 today and the thing is soo much faster then my 12l4. the car was nimble out of the corners. Had to turn the steering travel down to 50 and speed down to 70% just to keep from doing donuts on the 180s.
yang lai
B44 conversion to T44 Craps Electric Off-Road 31 04-22-2011 06:06 PM
Electric Conversion REVO, who makes the best conversion? rclab1 Monster Trucks 3 11-25-2007 12:27 PM
CONVERSION 32819toon Nitro On-Road 6 05-02-2006 01:07 AM
WTB a LCG conversion kit MoFO R/C Items: Wanted to Buy 0 09-24-2005 07:40 PM
