Old 04-27-2005, 12:59 PM   #1141
Default Re: need help real bad
Originally posted by SA_Racer
I managed to get out to the track today and tried my 1/12. I cant find anything wrong with the car but I cant get it to run in a straight line, cornering is also very twitchy and mostly just spins out.
The car setup is as follows for asphalt
10 Deg Uprights
.022 springs
1 deg camber
Brace removed
Purple fronts
Hitec servo mounted flat
4.5 mm clearance
Rear
Dampening washers
40wt oil and olive spring
Pink tyres
I checked tweak…..OK
No bearings are binding
Tried the diff loose and tight
Tried compound on rear wheels only as well as rear and front.
It seems no matter what I do, as soon as I go on power , I loose the car. If I accelerate slowly or freewheel it goes perfectly straight
Put the 5 degree caster blocks on the front. You might even want to try the 0 degree blocks if you can get the body to fit in the front. Add more static caster (both white shims in the front position). You should be using the thin T bar (.063) and only two screws where the T bar mounts to the lower motor pod plate. Always use 12 balls in the diff. You should be able to lock the diff up and the wheels spin freely. The distance from the center line of the car and the outside edges of the rear wheels should be equal. You did not mention what you are using on your dampener discs but the softer the side to side movement of the motor pod, the more rear traction. The only other thing you might try is mounting the servo at an angle to minimize the bump steer.
Crashby is offline   Reply With Quote
Old 04-27-2005, 01:45 PM   #1142
Merciless's Avatar
Send a message via ICQ to Merciless
Hi all,
Just wondered, are there any plans to make a "TRUE" lowered rear pod ??
Just as it stands, the smallest rear tires i can go too is 46mm (before i drop below 4mm ride height) and to be honest they are still very useable !!
Other than this the car is great
Sorry if this has been asked earlier in the thread but i must have missed it
Thanks again
Rod
Merciless is offline   Reply With Quote
Old 04-27-2005, 02:42 PM   #1143
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
SA_Racer...
I agree with the info posted... The Hitec servo will not center... I tried it in a 1/18 car and it didn't work!! The thin t-bar with 2 screws would help too. I really think it's the Hitec servo causing all the problems. What tire traction did you try?
Merciless...
How much droop do you have in the rear pod? On carpet I'll run 1mm droop and run my tires to 44mm with the #4 adj. and have 3.3 to 3.4mm clearance at the back corners of the chassis. I start to loose traction when the tires get to 44.5mm at the end of the race. There doesn't seem to be enough rubber to keep traction the full 8 minutes, but even lower plates can be talked about. I just didn't have any luck with them. Let me run it by Jason!!
Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 04-27-2005, 02:44 PM   #1144
Send a message via AIM to NuckingFutz Send a message via Yahoo to NuckingFutz
im very happy with the BMI chassis..i was faster at my local track for a change..the handling was superb man what are you guys gonna come up with next...Thanks for designing a car that accually works~Jason
NuckingFutz is offline   Reply With Quote
Old 04-27-2005, 02:48 PM   #1145
sg1
sg1's Avatar
Glad you like it... You have a PM!!
Wayne
Old 04-27-2005, 02:58 PM   #1146
10 Deg Uprights
.022 springs
1 deg camber
Brace removed
Purple fronts
4.5 mm clearance
Rear
Dampening washers
Pink tyres
Have you tried different rear tires...i know this sounds silly but i tried pinks(rear) at my track and had the same effect but when i changed to greys or whites the car came back to me no matter what i did ...just trying to help
Old 04-27-2005, 03:06 PM   #1147
Merciless's Avatar
Originally posted by sg1
SA_Racer...
Merciless...
Wayne
1mm of droop to but i'm trying to stay over 4mm ground clearence always (bumpy tracks)
There just seems to be more useable life in those tires when i run out of spacers to raise the rear
Thanks for the quick reply too !!
Old 04-27-2005, 03:11 PM   #1148
sg1
sg1's Avatar
Merciless...
Try starting your tires larger and change ride hgt. adj. Where do you start at?? I go up to 48.25 and the car still feels good. You can glue the side walls if you want to go a bit bigger. Just a thought...
Wayne
Old 04-27-2005, 03:20 PM   #1149
not to change the subject but what about a carbon fiber axle from BMI that would be sharp real sharp
Old 04-27-2005, 03:44 PM   #1150
Merciless's Avatar
Merciless...
Wayne
Big tires are cool, i just don't want to have to throw them out so fast just cause there getting down alittle.
Cheers, but i know what the adj.'s are for and how to use them.
I usually just take a mm or 2 off from new use them for a few club race nights till i get them down to 46/47 then save them for events but when they go down to 45mm or so i like to be able to use them again for club nights where possible just to save the £'s
there's no fun i buying tires all the time just cause i can
Anyway if the lowered pod is possible that'd be really kool and i'm sure they'd sell !!
It might make a welcome up-grade for new kits as using the spacers to raise the axel ain't all that bad on the Knife i used to run
Old 04-27-2005, 03:54 PM   #1151
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
maciless
found you
had a shock last friday running my 1/12th had to raise the rear pod cos i lost 5 mm of tyre through wear in one evening
also i brought some carbon fibre spacers that go under the front blocks to get the ride hight down
they are i piece jobbies undo both screws on front just slide the i piece thingy in come in 1.0mm,1.5mm.2.0mm sections
fibrelyte is the company
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 04-27-2005, 04:04 PM   #1152
Merciless's Avatar
Originally posted by MR JOLLY
maciless
found you
Hi Colin !!
Good to hear from you and i hope your well ?
Got the fibrelyte spacers good ain't they, really easy to use too.
But thaks for thinking of me and posting !!
Rod
Old 04-27-2005, 08:26 PM   #1153
SG1>> Your stuff went out!!!!!!
Bud Bartos is offline   Reply With Quote
Old 04-28-2005, 06:23 AM   #1154
sg1
sg1's Avatar
Bud,
I hope you didn't let Tang touch any of it!!!
Old 04-28-2005, 06:40 AM   #1155
Wayne did you get thosw pics lastnight?if so what did ya think?
B44 conversion to T44 Craps Electric Off-Road 31 04-22-2011 06:06 PM
Electric Conversion REVO, who makes the best conversion? rclab1 Monster Trucks 3 11-25-2007 12:27 PM
CONVERSION 32819toon Nitro On-Road 6 05-02-2006 01:07 AM
WTB a LCG conversion kit MoFO R/C Items: Wanted to Buy 0 09-24-2005 07:40 PM
