Old 04-07-2005, 02:52 PM   #1021
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Hey Stephen...
Let me know if you need anything else... Tell Dad to call if he has any questions when putting it togather!!
Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 04-07-2005, 08:02 PM   #1022
Send a message via AIM to jumbo360
Hey guys just wondering have any of you guys put the crc damper tubes on the car, and how do they work because I tried them on my rugrat and they were horrbile so i actually put a damper plate on. How would it work since there is no rebound and i dont think the t-plate rebounds does it?
Just wondering,
Justin
jumbo360 is offline   Reply With Quote
Old 04-07-2005, 08:14 PM   #1023
sg1
sg1's Avatar
Hey Justin,
I think most of the guys running the BMI conversion started with the CRC tubes. I tried them and could turn faster lap times then with the dampner washers, but not as consistant. There are alot of guys now using a 3 shock set up. There are pics a few pages back. I tried it in mod. and had good success with it. The following week I ran that set up in stock and had to change springs and ended up with good results. It all depends on how you like the car to feel. There are some guys also running a .078" to .080" t-plate which is out of a higher quality fiberglass and returns to center better.
Wayne
Old 04-07-2005, 08:36 PM   #1024
Oh okay thanks Wayne I was just wondering because it didnt work out to well for me in the past. I might wanna try the three shock setup, should you use thicker oil in the side shocks? I gotta go and get some shocks then.
Old 04-08-2005, 05:18 AM   #1025
sg1
sg1's Avatar
Hey Justin,
I ran 40wt. oil with gold springs. I've tried 35 and 50wt. and silver and black springs. It depends on the shock angle, but that would get you close.
If you need shocks let me know. I'm working on a line of products and the vcs shock is one of them. It has a TiCN coated shock shaft and a remachined piston to be concentric to the shaft and radiused. The complete kit goes for $16.00, but if you need 2 I'll cut you some slack
Wayne
Old 04-08-2005, 06:15 AM   #1026
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
BMI 1/12th scale rocks!
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 04-08-2005, 07:06 AM   #1027
JohnB's Avatar
Default Side shocks
The hardest thing for me with the side shocks was getting them to have equal dampening. I have one of those Losi shock testing tools from offroad racing. I modified it to work with with the VCS shocks. That helped a little, or at least let me check the pair together to make sure they had the same dampening.
take care
john
JohnB is offline   Reply With Quote
Old 04-08-2005, 07:10 AM   #1028
sg1
sg1's Avatar
I knew John had a trick...
Old 04-09-2005, 02:56 PM   #1029
Wayne you got PM
Old 04-09-2005, 03:08 PM   #1030
Does anyone know anyone who can anodize...?
Old 04-09-2005, 04:12 PM   #1031
protc3's Avatar
there are alot of places that do anodizing.the only problem is there is a minimum charge of 65-70 bucks.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-09-2005, 04:44 PM   #1032
wow thats kinda expensive, only reason I wanted anodizing was because I wanted to buy your kit but all the other stuff I have to put on it are already purple and I wanted to just take the Pods and whatever else is aluminum and just get it anodized.
Old 04-09-2005, 05:56 PM   #1033
nmt6789's Avatar
Send a message via AIM to nmt6789
Jumbo, I know a kid who anodizes............ his username is Ae Racer......... not to be confused with Ae_racer
nmt6789 is offline   Reply With Quote
Old 04-09-2005, 06:50 PM   #1034
How are his prices
Old 04-09-2005, 08:16 PM   #1035
sg1
sg1's Avatar
Jumbo360...
Back at ya!!1
B44 conversion to T44 Craps Electric Off-Road 31 04-22-2011 06:06 PM
Electric Conversion REVO, who makes the best conversion? rclab1 Monster Trucks 3 11-25-2007 12:27 PM
CONVERSION 32819toon Nitro On-Road 6 05-02-2006 01:07 AM
WTB a LCG conversion kit MoFO R/C Items: Wanted to Buy 0 09-24-2005 07:40 PM
