Old 03-11-2005, 07:41 AM   #811
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Default SG1 Edition parts
JohnB....
I knew you had it in you.... they look great The car set up looks good too!! Let me know how the new coating on the ball studs work out!! The coater is waiting to run them.
Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 03-11-2005, 08:08 AM   #812
JohnB's Avatar
R/C Tech Charter Subscriber
Thanks, I had a pretty hard time getting the parts to show through the plastic. Your header card looks good though, good job.
Yes sir, I'll give you a call Sat. night and let you know about the ball studs.
take care
john
JohnB is offline   Reply With Quote
Old 03-11-2005, 08:29 AM   #813
sg1
sg1's Avatar
John,
What class are you running at your big race??
Old 03-11-2005, 09:47 AM   #814
JohnB's Avatar
12th stock for sure. Not sure what else.
Old 03-11-2005, 03:10 PM   #815
sg1
sg1's Avatar
John,
Did Gus's package show yet??
Old 03-11-2005, 03:53 PM   #816
theisgroup's Avatar
hey guys
those with the conversion. I have a question. I have just gotten the conversion. I am trying to figure out some things.
1. i see from johnb's car that the shock mount is the part just infront of the front tbar mount. do you have to cut down the ball cups on the shock to mount it there? my shock seam to be fully compressed when mounted in that position.
2. I see the hole for the battery slots. what are the slots in between the 2 cells and how do I use it?
thanks
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-11-2005, 05:54 PM   #817
JohnB's Avatar
No package for Gus yet.
theisgroup - Yes you do need to cut them down. The overall shock length on my car is about 2.16" center to center of the ball cups. The little slots are for some sort of battery retention thing. I've never messed with any, my batteries have never moved at all. You will will shocked how easy it is tape the batteries in the car!
take care
john
Old 03-11-2005, 11:37 PM   #818
theisgroup's Avatar
we have a state race this weekend. I put together the bmil4 and it was fast and it's trasition is just awsome. I need to tune out some steering, but other then that it is a great addition to the bmi stable.
JohnB, thanks for your help. If you have any suggestions on setup, that would be great. I basically have a stock l4 setup on it at this point. but only put 2 packs into the car.
yang lai
Old 03-12-2005, 06:10 AM   #819
sg1
sg1's Avatar
theisgroup,
The battery stops are not done yet... I'll get them to you as soon as they are finished. John is correct about trimming the ball cups down a bit for the shock. I never measured the overall length of my shock, but I'm sure the dim. John gave you is good. The rest is pretty simple. I can give you my stock set up, and I'm sure others will have input and suggestions... Use what works for you!
Front:
CRC purple tires 1.78"
Niftech traction 3/4 of tire (center only)
No shims under a-arms
.020" springs
1 deg. camber
5 or 10 deg. uprights
servo mounted flat to chassis
4mm clearance
Rear:
.070: t-bar to start (assoc)
Magenta CRC rears 1.83"
Niftech traction 7/8 of tire (center only)
Dampening washers with 100 wt. oil
2 screws in t-bar
30 wt oil and green spring
4.5mm clearance
#4 ride hgt. adj.
Old 03-12-2005, 06:01 PM   #820
John Fontaine's Avatar
Send a message via AIM to John Fontaine
My BMI is all built and ready to rock tomorrow. Looks beautiful and I think it will handle awesome!!
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 03-13-2005, 05:24 AM   #821
sg1
sg1's Avatar
John...
Let us know how it goes, good or bad
Old 03-13-2005, 10:27 AM   #822
fatdoggy's Avatar
Well guys I drove it last night. Damper tube setup BMI L4.
First impressions
- Tons of steering
- Stuck rear end
- Neutral handling
- Very easy to adapt to
- SMOOTH!
It really handles like a dream and I'm extremely happy with it. Definately worth the wait! Compared to the L4, it carries more speed through the corners, is smoother and doesn't push or break out the rear end if pushed to the limits. I let four other guys(faster then me) run it last night and all liked it alot. All adapted quickly and were pushing it hard after a lap or 2.
This car handles better with a setup that I pulled straight out of my arse then my L4 did after a month and a half of tuning. And I actually thought my L4 handled well.
You guys have a winner here, thanks Wayne, Jason this car kicks arse. I can't wait to get on the track again this wedneday and run some hard packs through it. I had to work yesterday and only got about 2 hours at the track. I'll be sure to let a few other guys run it and see what they think.
Wayne - Have you had any of the graphite cross braces break yet? If I ever break one I'd need a hook-up.
Cheers,
Matthew.
fatdoggy is offline   Reply With Quote
Old 03-13-2005, 10:39 AM   #823
sg1
sg1's Avatar
Default BMI 1/12 conversion
Matthew,
Glad things worked out well. I have never broke a main chassis brace, YET...lol... I felt the sames thing you did, the car doesn't break free no matter how hard you push it. When I run stock I don't let off more then 3/4 throttle. In mod. I let it roll at 1/4 throttle, but never fully off. I think you may even like it better with the dampening washers. I felt with that set up the car was more stable and I could run more consistant lap times, but it is up to you and your driving style. Good luck, and let me know if you need anything!!
Wayne
Old 03-13-2005, 03:05 PM   #824
dakrat's Avatar
wayne, ugpm
dakrat is offline   Reply With Quote
Old 03-13-2005, 04:47 PM   #825
sg1
sg1's Avatar
Dakrat...
Your questions are answered
Wayne
B44 conversion to T44 Craps Electric Off-Road 31 04-22-2011 06:06 PM
Electric Conversion REVO, who makes the best conversion? rclab1 Monster Trucks 3 11-25-2007 12:27 PM
CONVERSION 32819toon Nitro On-Road 6 05-02-2006 01:07 AM
WTB a LCG conversion kit MoFO R/C Items: Wanted to Buy 0 09-24-2005 07:40 PM
