Old 01-24-2005, 08:47 AM   #616
JohnB's Avatar
R/C Tech Charter Subscriber
There are two sets of holes in the Top Plate for the damper mounts. I notice with the dampers in the most rear-ward holes the dampers look parallel with the chassis, didn't measure, just eyeball. In the forward holes the dampers sweep a little back. Which is better? I guess in my mind, the closer to the same plane as the T-bar pivot the better. So the rear holes are a good starting point?
take care
john
JohnB is offline   Reply With Quote
Old 01-24-2005, 09:03 AM   #617
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Hey John..
The hole position back farthest would keep the tubes straight... And the holes forward put them at a slight angle, as you saw... I tried both positions, It seemed like the farthest back position was the best... If you try both you'll see the dampening changes with the farthest forward position, kinda like changing the shock angle on a shock mount... You can also change the feel by shimming the ball studs to flatten the tube out more...
Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 01-24-2005, 09:27 AM   #618
WVRACER's Avatar
Send a message via AIM to WVRACER
is it possable to make a set of carbon fiber ride hight adjusters?
i would guess thay would last a very long time
wvracer
WVRACER is offline   Reply With Quote
Old 01-24-2005, 10:23 AM   #619
Trader Rating: 14 (100%+)
sg1:
Hi,
did you cut the steering blocks down like we used to do ????? I am having some ackerman issues with the chassis that Mini is running and was wondering if the cut down steering blocks were part of the problem. I also put the pod on you sent. Thanks it works great!!!!!!!!!!!
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 01-24-2005, 10:45 AM   #620
sg1
sg1's Avatar
wvracer...
I'm sure it's possible... I'd be concerned about it delaminating...
timxlb..
with the 12L4 front suspension I didn't move anything... Make sure your servo is slightly forward, and that the turnbucles are level (parallel) with the chassis... I haven't noticed any problem with the ackerman.
Wayne
Old 01-24-2005, 12:02 PM   #621
JohnB's Avatar
Default damper tubes
Perfect, thanks. I played with the angles a little last night. Using CRC tubes, .018 front springs inside, a short spacer (don't remember the legth now) and the middle hole on the outter mount is just about right to put no pressure on the springs with the chassis sitting neutral. When I rotate the chassis so it drops about 1/16" then they touch the spring. I'll start there and see what it does.
take care
john
Old 01-24-2005, 01:10 PM   #622
sg1
sg1's Avatar
No problem... let me know how it goes..
Wayne
Old 01-24-2005, 01:23 PM   #623
rayhuang's Avatar
Wayne
Wayne-do you remember what your fastest lap was and what your best run was last Sunday?
Thanks speedie,
Ray
Old 01-24-2005, 04:17 PM   #624
sg1
sg1's Avatar
Ray.. it was a 34 8:07... I think I was 13.8's up front and 14.4 at the end... I don't think 35 is possible in stock, that was a pretty clean run...
Old 01-24-2005, 04:36 PM   #625
rayhuang's Avatar
Wow-thats fast. Thanks for the info-wanted to compare some notes!!!
Old 01-25-2005, 06:54 AM   #626
sg1
sg1's Avatar
Is that good or bad Ray??? Did you run 1/12 last week??
Old 01-25-2005, 07:15 AM   #627
John Fontaine's Avatar
Send a message via AIM to John Fontaine
That sucks... I would have got atleast 37 laps in stock. j/k
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 01-25-2005, 07:57 AM   #628
rayhuang's Avatar
I think its good. Pete was on a fast 33 lap run, but he slowed to a 33 8:10 I think. I never got a perfectly clean run-but I did a 33 8:13 with a couple 16 sec laps. So-maybe a 33:10 was possible for me.
Old 01-25-2005, 03:45 PM   #629
whynot's Avatar
Trader Rating: 18 (100%+)
You guys suck.You arent good unless you can hit the boards as much as I do and still get 30 laps.Lets see you do that huh you guys make it to easy when you dont hit anything.hehe
mike
whynot is offline   Reply With Quote
Old 01-26-2005, 01:29 AM   #630
sg1:
Hi,
Found my little problem.............. I just needed to change ball studs....... I had long ones on the the S.B. and needed short ones for thr B.M.I. car.
This weekend is out....work I need a job where I can work around the races not through them. Mini says Hi. and is a little pissed about this weekend. but there will be others.
B44 conversion to T44 Craps Electric Off-Road 31 04-22-2011 06:06 PM
Electric Conversion REVO, who makes the best conversion? rclab1 Monster Trucks 3 11-25-2007 12:27 PM
CONVERSION 32819toon Nitro On-Road 6 05-02-2006 01:07 AM
WTB a LCG conversion kit MoFO R/C Items: Wanted to Buy 0 09-24-2005 07:40 PM
