Old 12-30-2004, 06:59 AM   #541
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
theisgroup..
Pretty much.. I would recommend running the servo flat on the chassis, but it's up to you. An antenna mount too is needed!!
Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 12-30-2004, 07:02 AM   #542
theisgroup's Avatar
wayne,
it sound like for not much more, you could have a 12th scale. I have one coming and have been running a 12l4. just wondering if I should leave the 4 alone and put a second togther with the bmi chassis
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 12-30-2004, 07:31 AM   #543
sg1
sg1's Avatar
It's always nice to have 2 cars Just in case....
Old 12-30-2004, 07:32 AM   #544
ChrisP's Avatar
There seems to be a bunch of little stuff....
Front end..rear axle, T-plate pivot balls and holders, ride height adjusters, bearings, shock, that all add up slowly but surely...it's a tough call to decide which way to go...I guess it mainly depends on what parts you already have sitting around
ChrisP is online now   Reply With Quote
Old 12-30-2004, 07:42 AM   #545
sg1
sg1's Avatar
True... Alot of guys have extra stuff laying around... and sometimes you can find a deal on stuff at the track... To convert the car back and forward doesn't take long... Maybe try the stock Assoc. car, then have the conversion built and ready to slide in the parts and give that a whirl... The only way to see and feel a difference..
Wayne
Old 12-30-2004, 07:48 AM   #546
theisgroup's Avatar
i am kind of luck. have been waiting for the bmi conversion for soooo long that I have all the upgrade parts picked out. With just a little more of the stock stuff like front end, and I should have all the parts for another car with the bmi.
yang lai
Old 12-30-2004, 07:52 AM   #547
theisgroup's Avatar
on a side note. Since I am new, I have a question. If I setup the car at the beginning of the day at say 3.5mm ride height, through the day the ride height changes due to tire wear. And I understand that part. But the front wears less then the back tires. And I still have 3.5mm in front, but only 3.0mm in the rear. Do you change out the shim in the rear axle and re-true tires to get even ride height? I am so not use to this, I can adjust this out in a tc by preload of the shock.
yang lai
Old 12-30-2004, 08:33 AM   #548
Registered User
OB42TC3's Avatar
You can use the rear axle inserts to raise the rear or add washers in the front to lower the front. Tamiya makes some wheel apcers for TC that work well in the front and IRS has some arms that are milled .060". The stock AE big al washers are .060 and the tamiya washers are .020 and .040. I made up a spreadsheet where I can calculate the spacers/axle blocks I need. w/o the trial and error.
OB42TC3 is offline   Reply With Quote
Old 12-30-2004, 08:43 AM   #549
theisgroup's Avatar
great. sounds like fun.
thanks for the help
yang lai
Old 12-30-2004, 09:16 AM   #550
sg1
sg1's Avatar
Changing the shims in the front or ride hgt. adj. in the rear will work... just remember to change the ball stud hgt. on the stearing block if you shim or de-shim the a-arm to set ride hgt.... Your bump stear will be altered if you don't... I typically start with 4mm front and 4.24mm rear for practice, then by the end of the day I'm at 3.25mm front and 3.5mm rear... I usually skim the tires on the truer to keep the same relationship of the tire diameter from front to rear... and recap the radius to keep the same feel on the track....
Look for some .030 hard anodized aluminum washers from BMI in the near future for fine tuning There may be a few other trick things too
Wayne
Old 12-30-2004, 04:48 PM   #551
XrayRacer's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to XrayRacer
Thanks SG1 for your input. I probably just should of waited for the Conversion and then bought the extra things I need to complete the car. I guess that is what I get for being impatiant. Is there any other servo you migt recommend other than the Futaba. What about Hitec?
Thanks again
- Clark
XrayRacer is offline   Reply With Quote
Old 12-30-2004, 05:05 PM   #552
sg1
sg1's Avatar
Clark..
I've had no luck with Hitec servos... airtronics, jr, or ko would be a better choice... As long as you have at least 40 oz. of torque with a quick responce time it should be OK...
Wayne
Old 12-30-2004, 07:49 PM   #553
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Futaba make a mini-digital servo? When I get my car back from jason as well as the conversion I want to use a HRS receiver and that only uses dig servos. Any suggestions? Right now i'm using a hitek 81MG servo and it's not that great....i'd rather have it as a backup for my Xray M18 or Mini-T.
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 01-01-2005, 05:04 PM   #554
ChrisP's Avatar
Any word on the build status?
Are the kits still in the works or has it been put on hold pending the TC4 project?
Old 01-02-2005, 01:57 PM   #555
XrayRacer's Avatar
Thanks again SG1-I am going to go with the Airtronics 94145Z High Speed Servo with its .07 transist time should fit the bill.
- Clark
B44 conversion to T44 Craps Electric Off-Road 31 04-22-2011 06:06 PM
Electric Conversion REVO, who makes the best conversion? rclab1 Monster Trucks 3 11-25-2007 12:27 PM
CONVERSION 32819toon Nitro On-Road 6 05-02-2006 01:07 AM
WTB a LCG conversion kit MoFO R/C Items: Wanted to Buy 0 09-24-2005 07:40 PM
