Racing on polished floor (basketball court)
we used to put silcone on our tires and then true them up.
I raced like this with 4 wheel drive off road cars for years. Schumacher yellow full spikes. I don't know if you can get them for a sedan, Adrian should be able to tell you.
Chris.
Chris.
how clean is the floor? run the softest rubber you can find but the tire will start collecting dust after a few meters if the floor is not very clean.
You can also try running foam.
have fun drifting!!!
Yes we found that you needed big knobbly spikes to cut through the dust.
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
TYRES
You will need these from schumhacer
u6671 yellow 20mm tyre with u6634 20mm sponge insert
u6623 yellow 25mm tyre with u6626 25mm spomge insert
Hop this helps we in the UK race quite alot on polished wood floor
The first set of part numbers are for narrow minipins, usally the quickest for the top boys but they wear pretty quickly
The second lot is for wide tyres although they won`t be the fastest they will last longer
maybe if u mopp the floor up with soap and water , there will be no dust and it will add traction, . Kause in my kitchen floor while its tsill wet, I ran my car on it with foams and it was on rails.
Shop Owner
You mean the woodlike court. If this the case I have played on one. The only tyre that had grip (amazing grip I might add) is the HPI rally tyre with soft or soft/medium insert!
You will be suprised with the grip !!!
Kyosho's rally tyres are ok but HPI's was the best!
Nick
Nick
Nick
Nick
Go with MR Jolly's suggestion, Schumacher mini pins are the tyre everyone uses in the UK when racing on wooden floors.
You can get blue compound which is a bit harder but you'll be down on grip to anyone using yellow.
Wide vs narrow can be down to grip, car balance or simply what the driver prefers. The amount of dust and even the kind of dust can make a big difference.
Some places new tyres are a must, others want tyres that are a few runs old or anything up to completely bald. In the hall I used to race in I always found new tyres slow, lost you atleast a lap since the car was wobbling around on the long spikes, you couldn't get as much corner speed and acceleration was poor too (not a lot but enough to know you were at a disadvantage)
Yet at another hall you either had brand new narrow tyres or you were drifting off into the wall
