How do you clean up CA on rubber tires? >
Old 03-12-2011, 08:57 AM
Default How do you clean up CA on rubber tires?
Wondering what the best way to clean up a sloppy tire CA glue job is on rubber tires. I'm thinking acetone but I don't want to wreck the rubber.
Thanks in advance for the responses.
Electro-MAX RC is offline
Old 03-12-2011, 09:34 AM
SteveP's Avatar
If I've ever been sloppy with the tire glue on on-road tires to the point that it's going to affect traction, i.e. glue on the tread, I use a Dremel tool with a fine grit sanding drum or a wire brush.
SteveP is offline
Old 03-12-2011, 09:58 AM
YoDog's Avatar
Trader Rating: 28 (100%+)
Nitromethane will desolve ca glue. Just wet a rag with 30% and rub away.
YoDog is offline
Old 03-12-2011, 06:14 PM
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I have had limited success with CA-uncure.
andrewdoherty is offline
Old 03-13-2011, 05:37 AM
You could try the super glue remover also. I have used that on things in the past including fingers and it works pretty well.
Lynn
CobraRman is offline
