Old 02-05-2005, 10:45 AM   #31
arawak420's Avatar
Send a message via Yahoo to arawak420
or use a heavier weight oil
arawak420 is offline   Reply With Quote
Old 02-05-2005, 03:52 PM   #32
Send a message via AIM to greencactus3
Originally posted by GReddy
if the oil freezes up in might damage the insides when the shock gets a strong sudden impact id use the friction shocks or get some shock sox
whats a shock sox?
and heavier oil is harder to freeze?
greencactus3 is offline   Reply With Quote
Old 02-05-2005, 06:41 PM   #33
GReddy's Avatar
Send a message via AIM to GReddy
shock sox is that it sounds like its a sock for ur shocks
http://www.shocksox.com/
GReddy is offline   Reply With Quote
Old 02-05-2005, 07:34 PM   #34
tel
Use Serpent cleaning putty around all the holes and wires on the receiver and ESC. This will keep the water out of the electronics and is easily removed. I ran in standing water at the last HPI World in Halifax England with only Serpent putty to keep the water out of the electronics and never had a problem.
Spray all the metal pieces and bearings lightly with WD40. This will repell the water so it won't puddle up and rust.
Most importantly take a hair dryer and dry off the car after each run to avoid rust.
Water won't short your battery since it DC and waters resitance is in the megaohms.
I didn't bother with bagging the motor. As long as its not submerged a running motor will likely blow any water right out of itself.
In the picture the grey blob is KO 302F receiver under a mound of Serpent putty.
Hope this helps.
Travis Lewis
Team Kyosho, Team Orion, Avid RC, JTP RC
tel is offline   Reply With Quote
Old 02-05-2005, 08:26 PM   #35
FIRE RIDER's Avatar
When I take my lunchbox out mudding i use plastic bags, electricical tape duct tape( alot and alot of tape)
My lunchbox is almost water proof without that stuff. cept for teh motor and the servo opening and the top of the chassie. see pik
the car is in pieces becasue i ahvent run it in a while.
But wheni do run ti i put tape over the top and the openings on teh motor. and away i go. runnign with the batery and motor and tires compleatly under the mud.
Owner and original purchaser of LST2#000689. RPM Arms,Sway Bar Kit, TiNi Gears,HD center skid plate, FOC and Gear swap, 420Kingpins, wing kit, body. Stuff still to do/get for 2016 season: Replace engine.
TLR22 SCT2.0 ZTW 6.5 120A SSPro ESC and Motor
Tamiya LunchBox (Project Racebox) More later
FIRE RIDER is offline   Reply With Quote
Old 02-06-2005, 07:58 AM   #36
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
do the battery and servo need water proofing too?
KREATOR1 is offline   Reply With Quote
Old 02-06-2005, 09:48 AM   #37
some servos yes. but thats easy. i just lined the seams with hot glue. and the screw holes too. and battery you dont really unless you go run it in salt water or sumthing
Old 02-06-2005, 10:04 AM   #38
GReddy's Avatar
the servo u can use shoe goo too
Old 10-31-2005, 01:01 PM   #39
rs4rallydriver's Avatar
is there a way to seal that stuff without it overheating? i ran my rs4 rally with the inner body set, and it kept out the water, but the esc got so hot that the motor leads soldered themselvs together,caused a short and caught fire.... and now my car is on an extended vacation.
rs4rallydriver is offline   Reply With Quote
Old 10-31-2005, 01:21 PM   #40
V12
V12's Avatar
Im using a waterproof ESC now so there is no problem with overheating.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 11-01-2005, 05:43 PM   #41
you probably need to worry about gearing it more if it gets that hot. i run my rally with the inner body fine. doesnt get too hot. or if you're fancy i suppose you can make a sort of air snorkel lol. i wouldnt recommend it tho. play with your gearing, make sure youre bearings are free, no binding, and that the wheels arent rubbing on the innerbody when you have it on. it did for me a while
Old 11-02-2005, 12:03 AM   #42
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Question - How to water proof your car?
Answer - Stay out of the puddles.
It is remarkably that simple.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 11-02-2005, 03:00 AM   #43
StasI's Avatar
Every Easy Fix - Run at a INDOOR track
StasI is offline   Reply With Quote
Waterproof Servos prophet1978 Monster Trucks 6 10-18-2008 08:06 PM
Waterproof Servos prophet1978 Nitro Off-Road 6 09-20-2008 11:45 AM
Waterproof Brushless ESC? Kajman Electric Off-Road 0 08-31-2008 02:37 AM
Waterproof BL ESC mac853 Radio and Electronics 0 07-01-2008 03:47 AM
New LRP waterproof ESC SMaxxin R/C Items: For Sale/Trade 3 03-30-2008 08:38 PM
