Old 03-10-2011, 08:44 AM   #1
Default My motor not working....what happen?
hello. i just bought*9T/SL-3650M ezrun and my first run was normal everything was running fine.but when i play for the second time the motor was not working.
i already calibrate the throttle range and *the ESC is ok there is the red LED light when i press the throttle but the only problem was the motor is not running..what could be the problem?
hmbukhari is offline   Reply With Quote
Old 03-10-2011, 08:51 AM   #2
SuperEk4's Avatar
Trader Rating: 32 (100%+)
what was the motor temp when u last played? if it more than 80 degree its fried already.
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 03-10-2011, 09:18 AM   #3
Not sure about the temp.but im sure its not more than 80 degree.btw how to check if the motor is fried or damage?
Old 03-10-2011, 09:26 AM   #4
SuperEk4's Avatar
smell it, it has a electronic burnt smell. There will be very bad clogging also.
i presume u put 2s batt?
Old 03-10-2011, 12:51 PM   #5
Foxxrocket's Avatar
Do you mean 80F or 180F?
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 03-10-2011, 02:37 PM   #6
SuperEk4's Avatar
176 F
Old 03-10-2011, 04:14 PM   #7
There is abit of smell but no bad clogging and no burnt colour.im using lipo 30c 2800mah 7.4v 2s.is that wrong or what?
Old 03-10-2011, 08:26 PM   #8
its confirm that it was my ESC which is not working.good news is that my motor is fine.still confused what caused the ESC to not working.
Old 03-10-2011, 08:29 PM   #9
SuperEk4's Avatar
fan working? if fan fails the esc will get over heated.
how long did u play did u allow the esc n motor to rest?
2s is the norm for 1/10 cars, if 3s everything heats up with speed.
not ahappy rctech fellow member david saechow Chat Lounge 106 09-06-2009 06:25 AM
WORLD GT?? Who, What, Why? SWTour Electric On-Road 39 01-21-2009 01:00 PM
Motor Break DOES Higher AMP draw = better motor? Travis S Electric On-Road 13 02-12-2005 03:02 AM
