Old 03-10-2011, 06:04 AM   #1
tc3team's Avatar
Default Inboard rear suspension...
Is it unnessesary or just not a good idea to work with in general on r/c cars?
I've only seen one 4wd on road sedan build it into their cars (Predator DTM) but maybe there are others I don't know of.
http://img.photobucket.com/albums/v5...5/DSC_4165.jpg
the ta05ifs uses inboard front suspension, just wondering why they didnt design it with rear inboard suspension too.
Could the main problem be with it fouling the body shell
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 03-10-2011, 08:06 AM   #2
gubbs3's Avatar
Inboard suspension is primarily used on open wheel cars to get more parts out of the wind. With a full bodied car this is not needed. What most people think is that inboard/cantilever suspension can lower the center of gravity because you don't have the shock towers sticking up. In the picture you posted, both rear shocks are completely above the rear gearbox along with mounting hardware etc. Does this really lower the center of gravity? Add to that the additional parts needed to make it work, the points of movement which will develop slop and of course the additional unsprung weight. What you get is at best the same performance at a higher cost with more maintenance.
gubbs3 is offline   Reply With Quote
Old 03-11-2011, 03:06 AM   #3
tc3team's Avatar
True
Thanks for answering my question, just a thought I had...
Old 03-11-2011, 05:12 AM   #4
TryHard's Avatar
Originally Posted by tc3team View Post
True
Should add, part of the reason for the IFS on the TA05's etc, is to allow the use of the more extreme GT type shells, with low front ends. Try fitting one of thoose to a car with standard shock towers...!!
| THard.co.uk | Xray | MuchMore |
Old 03-11-2011, 09:03 AM   #5
Foxxrocket's Avatar
The Tigermoth LCG V10 has both front and rear shocks layed down flat. Can't get any more inboard than that.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 03-11-2011, 09:40 AM   #6
tc3team's Avatar
yes indeed!
As for the tigermoth, not something we would see much of in the UK, but an interesting car netherless!
Old 03-11-2011, 10:49 AM   #7
cheehtae's Avatar
Trader Rating: 15 (100%+)
Tamiya's old F201 has rear in board susp.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Inboard toe vs. Outboard toe mtc3od Electric On-Road 21 08-30-2005 09:28 AM
Front inboard toe EAMotorsports Electric On-Road 22 03-26-2004 07:05 PM
