Spare part compatible between CRC and XRAY? >
Old 03-09-2011, 08:37 PM
Default Spare part compatible between CRC and XRAY?
I need as soon as possible this item:
CRC 1/10th Left Clamp Hub (CLN1733)
I buyed this item from USA but i don't know if i will receive before my next race (Spain). For this reason i want to buy this spare in europe:
XRA375045 XRAY Aluminum Rear Wheel Hub (Left) (X10)
But first... i want to ask if i can use it. The rear axe have the same diameter?
THANK you in advance,
TyoBBS is offline
Old 03-09-2011, 09:04 PM
Team EAM
Trader Rating: 79 (100%+)
Yes it will have the same diameter and size to fit your car but it may be a little longer or shorter so you may have to change some shims on the axle to keep your width the same.
EA
EAMotorsports is offline
Old 03-09-2011, 09:38 PM
EA
THANK you for your answer. Let's go to find
regards,
TyoBBS is offline
Copyright İ 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
