Any other name for Denatured Alcohol? >
Old 08-30-2004, 01:46 PM
Default Any other name for Denatured Alcohol?
I live in Canada and I went looking for denatured alcohol for cleaning my E-Maxx and Revo. But I cant find it.
I can find other things, even Mineral Spirits Essence (thought it might be the same).
Any ideas? I checked Wal-Mart and Home Depot.
Thanx.
Galactik is offline
Old 08-30-2004, 01:47 PM
donoman's Avatar
My buddy said that Mineral spirits is same as lighter fluid.
He's kinda nutty but usually right.
donoman is offline
Old 08-30-2004, 01:49 PM
Ok, so I dont want the mineral spirit one.
So where can i find dentaured alcohol?
Galactik is offline
Old 08-30-2004, 01:52 PM
Cardboard's Avatar
Rubbing alcohol and isopryl alcohol are weaker versions of denatured alcohol.
Cardboard is offline
Old 08-30-2004, 02:32 PM
Dragonxmx's Avatar
Default Denatured alcohol
Denatured alcohol is ethanol (ethyl alcohol) mixed with an added agent to make it bad for consumption, usually methyl alcohol (methanol) and other agents.
Rubing alcohol is isopropanol (isopryl alcohol).
Lighter fluid is usually butane (good for cleaning lexan bodies), mineral spirits is a thin petroleum distillate used as a solvent or thinner(for paints).
Goof-Off is xylene, great for cleaning bearings.
Dragonxmx is offline
Old 08-30-2004, 02:43 PM
Where can I find denatured alcohol?
I checked Wal-Mart and Home Depot, but nothing.
Galactik is offline
Old 08-31-2004, 07:23 AM
Dragonxmx's Avatar
Default Where
You should try a pharmacy, I think rubbing alcohol will do if you cant find it. Ethanol is the alcohol in beer wine and spirits, that is why it's denatured-so you don't drink it. If it's listed say 95% it means 95% ethanol 5% water by volume. The alcohol evaporates quickly, water not so quickly (rust).
Neither is a particularly good solvent for hobby application though.
Old 08-31-2004, 07:28 AM
Mike Mandio's Avatar
Try a paint store. Denatured alcohol is also a thinner for Shellac. I find it at Home Depot or Lowes in the paint department.
Mike Mandio is offline
Old 08-31-2004, 07:30 AM
Old 08-31-2004, 11:02 AM
Qwiglee's Avatar
The Trinity Death Grip rubber tire cleaner smells like alcohol but it doesnt say what the ingredients are. I have started using mine for other things like removing old number decals.
Qwiglee is offline
Old 08-31-2004, 11:49 AM
Speedyjay's Avatar
Denatured Alcohol is used as a thinner in water based paint and solvents, so go to a paint store (like Scherwin Williams) and ask for a water based thinner.
Im really not sure if its called something else in Canada. Im also suprised Home Depot didnt have any?? Did you ask for it at the paint counter?
Mineral Spirits would work just as good if not better, its the active ingrediant in motor spray/brake spray.
Speedyjay is offline
