KO Pro  Pro EX10 Helios >
Old 03-08-2011, 01:41 PM
Default KO Pro Pro EX10 Helios
I just bought the EX10 Helios from a friend and I am tired of buying AA's. Anyone have a solution for a Lipo Pack? What kind of plug does it take?
HVManh44 is offline
Old 03-08-2011, 02:14 PM
stiltskin's Avatar
Trader Rating: 103 (100%+)
There are several that fit in the case. You may have to reverse the pins in the plug and put the black one in the center and the red one one the outside. You will have to make an adapter for charging after you do this.
stiltskin is offline
Old 03-08-2011, 09:29 PM
Still Bill's Avatar
Trader Rating: 16 (100%+)
Stormer Hobbies has a Reedy branded lipo that is made for the Helios/Eurus radios. You have to make up a fairly simple wiring harness to charge it.
Ballistic Batteries has a nice lipo with its own specific charger...Fairly expensive; but nice.
Still Bill is offline
Old 03-10-2011, 01:52 PM
do you guys know what kind of plug it takes? is it Futaba, JR, what kind of a connection? I can always take a mini airsoft battery and make one, I just don't know what kind of plug it takes. Also what happens if I plug it in with reversed Polarity?
HVManh44 is offline
Old 04-12-2011, 10:06 AM
burgboyz's Avatar
Trader Rating: 70 (100%+)
Reverse polarity will fry the power switch...Thant is if you are lucky enough it stops there!!!
burgboyz is offline
Old 04-12-2011, 11:55 AM
gubbs3's Avatar
Its a $48 repair from KO...
gubbs3 is offline
Old 04-12-2011, 12:00 PM
smokinu's Avatar
Trader Rating: 71 (99%+)
yup ProTek Pack for mine. the 2300mah lasts around a month or so on a single charge racing 2-3 times a week.
It came with instructions on witch way to put the pins in the connecter and witch way to plug it in..
i went a step further and broke out the exacto blade and marked witch side the positive wire should be on.. (my helios the pos wire is on the pin closest to the back of the radio)
Looks like proteks pack is a 2800 now
Makes sense it will last a bit longer.
http://www.amainhobbies.com/product_...k-111V-2800mAh
smokinu is offline
Old 04-21-2011, 12:06 AM
J-milz's Avatar
Trader Rating: 41 (100%+)
Default VR adjustment
A friend of mine turned on the VR setting on my Helios / JR Z1 radio and the car felt "better". Couldnt explain what it was exactly, but the car seemed mire tame. I read the manual to see what exactly the VR adjustment is, but I'm even more confused. Can anybody explain this in laymens terms?
J-milz is offline
Old 04-21-2011, 12:22 AM
CypressMidWest's Avatar
It adjusts the steering and throttle potetiometers in relation to the CPU to compensate for their wear over time. Do it twice a month and your radio will always feel the same from run to run.
CypressMidWest is offline
Old 04-21-2011, 07:37 AM
avs
avs's Avatar
+1 but Robert at KO will take care of it quickly. (apparently he's had a little practice)
avs is offline
Old 04-21-2011, 07:54 AM
syndr0me's Avatar
Trader Rating: 32 (100%+)
They're on the heavy side, but Eneloop AA's are incredible rechargeable NiMH cells. They have very little self-discharge. Don't charge them through the radio, though.
syndr0me is offline
Old 04-21-2011, 07:57 AM
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Related question to the LiPo pack. I have a checkpoint LiPo balancer. What type of connector/adapter would I need in order to charge the 3s transmitter pack?
tr1kstanc3 is offline
Old 04-21-2011, 08:50 AM
gubbs3's Avatar
The charge lead polarity simply needs to be reversed. All I do is switch the leads going into the charger. Most chargers have a reverse polarity alarm (check to make sure your's does) so if you forget to switch it back when you charge your next pack you won't do any damage.
Regarding the balancer, if you're talking about this balancer (http://www.amainhobbies.com/product_...-Poly-Balancer) I can't help you.
gubbs3 is offline
Old 04-21-2011, 07:42 PM
try this one, if your battery has a jst xh balance plug
http://www3.towerhobbies.com/cgi-bin...EARCH=tcpp9156
ercwhtsd is offline
Old 04-22-2011, 09:05 AM
tr1kstanc3's Avatar
Exactly what I was looking for. Thanks!
