Old 08-30-2004, 04:08 AM   #1
wolfracing's Avatar
Default schotty diodes
Do I need a schotty diode on a johnson 540 motor.
Using a Novac TC 2 , 3300 GP Nmih
Ued one when I run this with a mod, but wonderind if I need one for a 540
Wolf
wolfracing is offline   Reply With Quote
Old 08-30-2004, 07:43 AM   #2
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
i would use one just to be safe because i've fried ECS's with stock motors with no diodes it's always good to be on the safe side
Javen13 is offline   Reply With Quote
Old 08-30-2004, 10:00 AM   #3
whats thier purpose though? arent they only for forward only esc's i plan to get the novak fusion esc and a low turn motor and i'm wondering if i dont use one could i be putting my esc in a possition to be fried?
kh15 is offline   Reply With Quote
Old 08-30-2004, 11:06 AM   #4
koabich's Avatar
Send a message via Yahoo to koabich
Default Re: schotty diodes
Wolf
Yes, I would run one with that ESC. The schotty helps prevent unwanted interference and will help in smoothing out the throttle response.
koabich is offline   Reply With Quote
Old 08-30-2004, 12:23 PM   #5
GTO2's Avatar
R/C Tech Charter Subscriber
if my mind serves me right, it is for forward mode esc. It's somekind of reverse voltage protection to the ESC not so much for the motor especially during braking.
Those novaks should have at least one diode on their forward only esc.
driftercentral.com
GTO2 is offline   Reply With Quote
Old 08-30-2004, 12:30 PM   #6
GTO2's Avatar
Personally I think 540 Johnson doesn't need any schottky unless the ESC need to be protected; also because the motor does not draw (or generate-in braking) much amps that is as much as mod. Just my thinking
driftercentral.com
Old 08-30-2004, 08:40 PM   #7
does the novak exs esc some with a diode? whats are the chances that i will fri my esc if i dont solder one on my motor
Old 08-31-2004, 04:07 AM   #8
wolfracing's Avatar
Thanks guys, the novac tc2 is forward only, and quite expensive , so i'll go the safe option and install the schotty on the 540.
Just thought being 540 may not have needed one.
I've always used one when running stock and 10x2
Matt
schottky diodes in st's wfdfiremedic Electric Off-Road 11 09-04-2007 05:53 PM
Schottky Diodes macgyver1432000 Electric On-Road 4 03-19-2006 11:12 PM
Where to buy schottky diodes? cannon_eer7 Singapore R/C Racers 4 10-30-2005 08:24 PM
Stockky diodes blueskieshlg Rookie Zone 2 02-02-2005 08:10 AM
shockity diodes kh15 Electric On-Road 5 09-01-2004 08:35 AM
