Old 03-09-2011, 03:20 AM   #16
I had use this in my r5 with 3.5T motor and 1S lipo for sometime already. Have tried the LRP's competition v1 and v2 before. I think the HW 1S have a lot more punch than the LRP. Well, you can turn up the punch on the LRP but you will loose some throttle "smoothness". The HW just feel extremly smooth when you apply partial throttle but when you punch it it will give you lot of punch at the same time. And the brake is very progressive too. You can apply partal brake to slow the 1/12 down on those end of straight large corner!!!! I can't believe how good this thing is. Oh, btw: I can't remember what software it come with. But I tried to install different software and the lipo cut function keep kicking in..... Anyone know what software will work with 1S other than the stock one?
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 03-09-2011, 05:05 AM   #17
cherry2blost's Avatar
119 has issues with the cutoff, most racers turn it off, hopefully will be dealt with in the new software just being released.
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-09-2011, 02:18 PM   #18
Also carefull loading the 508 No Timing software onto the ESC. The low voltage cutoff will prevent you from using it. So when programming the ESC, use a 2S battery, and then turn the battery cut off to off.
Other then that is a good speedo, but the FW needs some minor adjustments.
Shawn.
Shawn68z is offline   Reply With Quote
Old 03-09-2011, 03:26 PM   #19
Default Setup Sheets
Hi here are some setup sheets I developed.
http://www.mediafire.com/?50y7w4xgpssi86b
PAN CAR ^^^^
Old 03-09-2011, 11:00 PM   #20
Thanks guys. I guess need a spend a little more time testing them one by one.
Old 03-10-2011, 12:10 PM   #21
mikeygar's Avatar
Trader Rating: 14 (100%+)
hey cherry2blost - thanks for the setup sheet - but for what motor is this setting applicable? I'm guessing for 13.5 or 17.5 since there is boost?
thanks!
mikeygar is offline   Reply With Quote
Old 03-10-2011, 08:12 PM   #22
thanks!
STOCK Boost is good for all motors above 10.5Turn
MOD Boost softeare is good for all MODS
Hope it helps
Old 03-20-2011, 09:05 AM   #23
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
any firmware and set-up suggestions running a 4.0BL motor? roll-out? Thanks!
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 03-21-2011, 06:19 AM   #24
ANy tips for 1cell mod on this ESC on a mod sofware? I will be running a 3.5 or 4T SP motor and need a good starting setup
chovden is offline   Reply With Quote
Old 03-28-2011, 01:51 AM   #25
Default BRCA Nationals Setup so far
Hi Just an update, our Driver in the UK has had his first outing with the New 1s ESC at a BRCA National and an 8th in the 'A' Final is a very respectable begining.
Brian Eldridge can now be unveiled as the 'Face' of Hobbywing in the UK and we wish him all the best and a successful series this year.
He is running the Hobbywing 1s in the new TOP 12th and it is super quick.
Well done Brian.
Setup will follow as soon as we have his race report.
Old 03-29-2011, 03:11 AM   #26
VooDooPH's Avatar
Old 06-30-2011, 10:39 PM   #27
Originally Posted by cherry2blost View Post
they are the same Spec as the v2.1 120A XERUN ecept they ONLY run 1s / 2s instead of 2s/3s. Heatsink and fan is INCLUDED as stated above and fit very easily.
We have some settings for 10.5 from a driver who is testing these and can help with those, Software is readily available and regularly updated.
ESC has proven very very quick in racing with a very good driver at the wheel
Hope it helps to answer some questions for you.
Cherry
guys whats the procedure for changing the heatsink from the flat one which is installed for to the larger fin type which is required for using this esc for 1/10 touring car?
Colo is offline   Reply With Quote
Old 06-30-2011, 11:38 PM   #28
mon
I'm now using a Tamiya TT01 kit what 13.5T Esc and motor combo is most applicable with this kit.
mon is offline   Reply With Quote
Old 07-01-2011, 01:27 AM   #29
Sorted now
Old 08-27-2011, 07:54 PM   #30
Default 1s esc
just got my esc in the mail and was wondering if anyone has some starting points for it ? ill be running it in a oval car 1s battery 17.5 motor open esc thanks in advance
ur2slw is offline   Reply With Quote
